04-19-2008, 10:03 PM | #1 |
A couple Qs
First off, does anyone know how to remove the choke cable that goes through the cluster panel?
Second does the rear view supposed to attach between the visors? I dont have any holes there. |
04-19-2008, 10:12 PM | #2 |
Chasin' the Dream
Re: A couple Qs
Don't know which year your referring to, but the mirrio on my 71 attaches to the roof via one screw on a raised area.
Sorry no pics but the cam went on a trip. Can't say about the choke. Jerry |
04-19-2008, 10:46 PM | #3 |
its all about the +6 inches
Re: A couple Qs
the mirror was optional untill 70. the only year for the raised mounting pad in the sheet metal was 71.
04-19-2008, 11:03 PM | #4 |
Lemme show you something!!
Re: A couple Qs
Regarding your choke cable- it's swedged onto the rod that goes through the gauge panel, so if you want to save it, you'll have to disconnect it from the choke plate on the carb, remove all the hold-downs and guides and pull the whole thing out as one unit.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
04-19-2008, 11:49 PM | #5 |
Need a bigger hammer..
Re: A couple Qs
I bought the later style rear view mirror that mounts to the windshield, that way I didn't have to drill a hole(s) in the cab.
1968 GMC 3/4 LWB fleetside Custom Camper 2018 Silverado High Country 2500HD Duramax 4X4 |
04-19-2008, 11:55 PM | #6 |
Jamie Hyneman is my twin
Re: A couple Qs
IIRC your choke is bolted to the metal dash under the plastic bezel. to remove it, you'll need to remove the bezel. Then remove the whole unit.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
04-20-2008, 12:22 AM | #7 |
Re: A couple Qs
I just cut the stem behind the pull and got rid of it since I needed to move the wiper switch to that loacation for the new bezel.
04-20-2008, 12:25 AM | #8 |
instagram "footbraker67"
Re: A couple Qs
just cut the choke out and put you one of these in
1967 lwb, bigwindow, factory air (converted to Vintage Air), custom option,4.5- 6 drop, TBI injected 355, 700r4, 5 lug, daily driver. 1967 Chevelle Malibu Drag car, 355, brodix heads and intake, powerglide, 10.82 @ 123 mph 1966 chevelle malibu, Street/strip, 355, spare parts from my other chevelle, 12.82 @104 mph 1968 lwb parts truck |
