Ah man is back spacing the worst or what
Ok last ? on it from me.
I need to know a good back spacing if you were to run 4 of the same Wheel/tire..... If you were to run 4 18X9 rims with Dunlop 275/35zr18 sp sport 8080e tires They are 26X10+ If I run 0 back spacing that center will be right at 4.5" right?? From all the search and bop and weave I think 4.5 - 5" backspace all around will work???? But I have no idea...... ![]() ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Re: Ah man is back spacing the worst or what
0 backspacing the flange is even with the inside bead of the rim and a 9 backspace the flange is even with the outside bead on a 9"rim
This might help you
http://www.rims-n-tires.com/rt_specs.jsp I'm always worried I won't have enough backspace and the outside will rub. At least if it's too much, you can add spacers.. Last edited by Mondo; 04-20-2008 at 03:45 AM. |
