Old 04-11-2008, 07:31 PM   #1
062500hd
putting 08 alloys on 06 hd
I'm looking to upgrade the wheels on my 06 regular cab 2500hd. I was looking at a set of takeoffs from an 08 that are 17" and an inch wider, and wondering if there would be any rubbing/ or other issues.It would be great to get some bigger tires on there! The 16'' steels arent cutting it anymore.
062500hd is offline   Reply With Quote
Old 04-12-2008, 12:40 AM   #2
Re: putting 08 alloys on 06 hd
Should be fine. Just remember your speedometer and odometer will not be as accurate anymore. It could be off a good bit,..ie you will be going faster than what the speedo registers because of the larger diameter wheel/tire combo.
Other than that you should be fine.
Oh yeah, welcome to the boards always glad to see new members.
Old 04-22-2008, 06:03 AM   #3
ed2552
ed2552's Avatar
to the board, should fit fine, not that much bigger, what does ur truck have for motor, trans, reg or crew cab, etc?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
