Wiring Help ?
1 I am going through my engine wiring harness and I am trying to figure out how do I convert to HEI what wires do I remove? I have heard you just connect to where the resistor wire comes out of the fire wall is that right ? and what colour shouls it be?
2 Also I am going to use a Internal regulated altenator so how do I wire that up. 1 wire alt is my plan so do I just use the red wire coming out of the firewall and connect it to the alt? I want to have a clean conversion, and get rid of all the crappy wires that are not being used. 3 Last one what colour wire should I have running to the starter? Thanks for your help Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Half a bubble off!
#1-search function should get the info you need.
#2-search will confuse you, I have the easiest, cleanest way, PM me if you are interested in details. #3-refer to #1, but it's really up to you.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
Sent you a PM
ttt
Check out the FAQ section on this site. To answer part of number one...use a larger gauge wire from the distributor to the fuse block instead of the resistor wire. I think I used 10 gauge. You can get rid of the wire from the distributor to the starter. Keep the wire from the cab/ignition to the starter. I hope this made sense. There are some really good instructions in the FAQ section...much better than mine.
The colours of the wires should be, I believe, yellow from the fuse block to the distributor, brown from the ignition to the starter and purple from the distributor to the starter(the one you are getting rid of). I think these are the correct colours. Let me know if I am wrong.
Thanks for the help I will see if that all works out tonight. Mario
