Old 04-23-2008, 05:43 AM   #1
jorgensensc
jorgensensc's Avatar
Shock question.
Hey all.
I am running airbags on the rear with shock relocators. What is the right kind of shock to run. Can I run the standard shocks or do I need to go with a lowered shock? Wasn't there a post about sizes of different stock shocks that could be used instead of buying the aftermarket nitro, belltech and such shocks? I was working on the rear when and when I pulled the monroes I found out one of them is completely worn out. Can I just re-run what I had (monroes)? I am running the stock style monroes up front with drop spindle and 1" lowered springs. Is that okay?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-23-2008, 01:37 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Shock question.
With shock relocators, I "think" you will be ok with stock length shocks.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-23-2008, 05:02 PM   #3
jorgensensc
Re: Shock question.
Thanks.
Anyone else?
Shawn
Old 04-23-2008, 05:21 PM   #4
SCOTI
SCOTI's Avatar
Re: Shock question.
Stock shocks work fine w/the relocation brackets on mild drops (6" or less). They'll get close to the limits of their travel designs w/o the use of lowering blocks if the drop is greater than 6". My 68 swb trucks rear drop was ~8" & used:
Firestone bags bolted directly in place of coils
1.5" CPP lowering blocks
Modified stock shock brackets (same as relocation kit)
Bolt-in style CPP c-notch
Adj CPP panhard bar
Off the shelf Gabriel HD gas VST shocks F/R
No problems in 5+yrs of the daily grind which included pulling a car trailer.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-23-2008, 05:23 PM   #5
jorgensensc
Re: Shock question.
Awesome! THat is what I'm looking for! Thanks Scoti!
SHawn
