my short bus
Re: 77 2wd w/ burb roof
whats up with the back window looks cool
do they swing apart or up look like the astro's with the 3 pc rear dr's
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
#2 | |
Looks like barn doors with no or shaved handles. That is the only thing I would have done different on the Hills Blazer. bagged74, you go through these pretty quick and often! Would it be possible to get some pictures of the rear door set-up; if its other than a standard 'burb barn door set-up. Also, on the Hill's truck, they extended the body after the rear wheels back a bit to make it the same length as a 'burb (behind the rear wheels). I thought this had to do with using a standard piece of 'burb side glass; is the glass on your Blazer standard glass or custom cut?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#3 | ||
its just $$$$$
![]() Quote:
how about some pics of the suicide door hinge setup? i've been thinking about doing that and have been trying to figure out the best way on a blazer.
we don't ask for a lot of pics, do we? ![]() |
#5 | ||
Oh wait, on the Astro's the bottom half split in the middle with a "hatch" on the top. That would be cool if executed properly. Quote:
In the article they have posted there from the Truckin's feature it says they extended the frame and body 2" to accomodate the 'burb roof. But I remember in one of the build pictures you could see the original taillight pockets behind the new 'burb section. IIRC there was a gap between the old and new pockets too. This left me with the impression that the rear section was at least 6" longer? Now that I am thinking about it, it might of had something to do with matching up the door frames; the rear of the 'burb rear door frame to the front door on the Blazer???
its just $$$$$
I cant say for sure how they did theirs, but the suburban window trim fits perfectly at the door on mine. This would lead me to believe that the length is correct without adding to the rear.
If you compare the pics of mine and Jason Hill's I think you will see the proportion look about the same. If they added to the rear it doesnt look to be very much. |
its just $$$$$
i stand corrected. after studying the pictures a little more closely, i can see the difference. i can also see that putting the barn door , or a burb gate for that matter, will be near impossible.
there probably is a slight difference in overall length. |
