Old 03-27-2008, 04:17 AM   #1
Tim64
Tim64's Avatar
Tranny update
Hey Guys,
I got the 700r4 bolted up over the weekend. Tanny lines are run, and I'm ready to hook up the TV cable. I'm running this tranny behind a 75' 250. Those of you who know these engines, and the 1bbl carbs on them know the linkage runs behind the carb 90 degrees from the way it would on a V8. I'm sure I can come up with something as my moto is "No job is too tough", I sure would love to hear from someone who has done this set up. TV that is. Some pics would be cool too. I have some update pics to post now, and I'll have more later.
Thanks,
Tim64 is offline   Reply With Quote
Old 03-27-2008, 04:19 AM   #2
Tim64
Tim64's Avatar
Re: Tranny update
Couple more.
Old 03-27-2008, 04:23 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Re: Tranny update
Looks very nice.......Im interested in the performance once you get it going. I thought this would be a nice combo for some type of ride.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-27-2008, 04:35 AM   #4
Bama_C10
Re: Tranny update
nice.
how about the driveshaft?have to shorten it?
Bama_C10 is offline   Reply With Quote
Old 03-27-2008, 05:02 AM   #5
1974k5blazer
Re: Tranny update
x2 on the drive shaft????? and how did that crossmember work out worth the money?????
1974k5blazer is offline   Reply With Quote
Old 03-27-2008, 07:54 AM   #6
greg64
greg64's Avatar
Re: Tranny update
Nice looking install, Tim. I know what you're describing with the throttle linkage. I haven't done the TV cable, but I'm thinking it might be easier to run it parallel with the fore-aft linkage. There's not a lot of room to work around the 90 degree bellcrank area. Could you attach the cable near the bottom of the first link (opposite end from where the pedal link attaches).
I'd start holding the cable up in the various possible orientations, and then think about which way would be easiest to build a cable mount for.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-27-2008, 02:35 PM   #7
Tim64
Tim64's Avatar
Re: Tranny update
Hey Guys,
Greg, I went back out to the garage after posting this thread last night, and I looking at maybe doing what you're talking about. My only concern is bending the cable 90 degrees. I've read where you don't want to do this, but this is my first TV cable, so I really don't how big a deal it is.
Yes, the driveshaft will have to be shortend. Around 2" or so I haven't got that far.
Yes, the crossmember is money well spent, unless you're some hot shot welder, which I'm not. It fit beautifuly.
Old 03-27-2008, 05:33 PM   #8
greg64
greg64's Avatar
Re: Tranny update
Tim, could the cable come in under the rear of the intake manifold, running parallel to the solid link on the top side? This would then connect at the place I was thinking of (bottom of the short vertical link). What have you got to work with on the end of the TV cable?
Greg
Old 03-27-2008, 08:16 PM   #9
Tim64
Tim64's Avatar
Re: Tranny update
I'll post some more pics tonight of the cable. I'm not 100% sure I know where you're talking about there Greg. Would you be able to post a pic of the link you're talking about?
Old 03-27-2008, 11:18 PM   #10
TimE
Hey Y'all!!
TimE's Avatar
Re: Tranny update
Look at the third picture in your original post. Greg is talking about the crank(linkage) that has the throttle rod, spring and carb linkage attached to it in the center of the pic. You might be able to run the TV cable parallel with the throttle rod but come in under the intake and attach the cable somewhere on this crank. Either way that you could route it (over/under the intake), this might be your best spot to attach the TV cable without binding it.
PS Sorry to butt in between you and Greg, just tryin to help out.
TimE is offline   Reply With Quote
Old 03-28-2008, 12:37 AM   #11
Tim64
Tim64's Avatar
Re: Tranny update
No problem TimE I need all the help I can get.
Thanks,
Old 03-28-2008, 04:28 AM   #12
greg64
greg64's Avatar
Re: Tranny update
Tim, I think TimE has the right idea. I've mocked up your 3rd pic to show what I was thinking in white. I was thinking that this would keep the TV cable from binding up, which might happen if you go across the engine (side to side instead of fore-aft).
Greg
Old 03-28-2008, 04:45 AM   #13
Tim64
Tim64's Avatar
Re: Tranny update
Hey Greg,
That will work great! I'm going to come up from under the manifold. I'll get it done this weekend and post some more pics, and hopefully tell you about the test drive.
Thanks so much guys!
Old 03-28-2008, 05:51 AM   #14
TimE
Hey Y'all!!
TimE's Avatar
Re: Tranny update
Good job Greg. Keep us posted on how it works out Tim.
Old 03-28-2008, 07:55 AM   #15
greg64
greg64's Avatar
Re: Tranny update
Glad you guys like the suggestion. You'll probably have to check the stroke of the TV cable, and then attach it to that bell crank at the appropriate distance from the pivot point so the travel works out correctly.
Greg
Old 03-28-2008, 08:31 AM   #16
protrash64
protrash64's Avatar
Re: Tranny update
I think greg64 has it all wrong. A Clliford intake and a 4-barrel would straighten things out!!!
Old 04-17-2008, 01:29 PM   #17
Tim64
Tim64's Avatar
Re: Tranny update
Hey Guys,
Been away for a little while, but I had the old beast out on the road yesterday. The Tv cable works as it should. What a difference the 700 makes over the old 3 speed. I'll post some pics tonight. Many thanks to all you guys who helped out, with some great ideas, and general info.
Old 04-18-2008, 04:40 AM   #18
TimE
Hey Y'all!!
TimE's Avatar
Re: Tranny update
Glad to hear it worked out for ya Tim. Now...where's the pics?
Old 04-18-2008, 07:32 AM   #19
greg64
greg64's Avatar
Re: Tranny update
Sounds great Tim! I'd like to see what you came up with.
Greg
Old 04-19-2008, 04:37 AM   #20
Texasdeere
Texasdeere's Avatar
Re: Tranny update
Good to hear!
I plan on doing this to my 64 soon. It has 4.56 gears and a 283. I am wondering how I will hook up the TV cable to an old 2 bbl.
Texasdeere is offline   Reply With Quote
Old 04-24-2008, 12:56 AM   #21
Tim64
Tim64's Avatar
Re: Tranny update
Hey Guys,
Here are some pics of the TV set-up. Looks kinda funky, but works great. I'm very pleased with how the swap turned out. Again many thanks to all you guys who gave ideas on this project.
Old 04-24-2008, 01:08 AM   #22
TimE
Hey Y'all!!
TimE's Avatar
Re: Tranny update
Looks like it worked out well. Good job Tim! Has this mod helped much on your gas mileage? I'm sure starting out from a dead stop feels better with the deeper ratio of 1st gear.
Old 04-24-2008, 12:54 PM   #23
Tim64
Tim64's Avatar
Re: Tranny update
I haven't checked the mileage yet, but I will be doing so next time I fill up. It sure does run down the highway a hell of a lot better. Next I'm going to add a tach, so I can see what the rpms really are. All in all drivability has improved greatly.
Old 04-24-2008, 01:25 PM   #24
TimE
Hey Y'all!!
TimE's Avatar
Re: Tranny update
Sounds good. Now put some miles on that puppy and enjoy.
Old 04-24-2008, 03:08 PM   #25
62 short step
62 short step's Avatar
Re: Tranny update
With my 283 700r4 with 3.08 gears, doing 70 mph the tach is at 1800 rpm's. I love this tranny!! Looks like you did a great job with yours!! Go enjoy it!!
62 short step is offline   Reply With Quote
