Building Rollbar
Hey all,
I've got a '71 K5, and with summer upon us... the top needs to come off, and a rollbar needs to go in. I'd like to build it to the same specs as one of the dealer installed units. Would somebody mind providing me with some basic dimensions on one of these bad boys... overall width across the bottom, hole spacing on bolt-down plates, tube diameter, height at which rear down tube attaches to main hoop, distance up fender well (from floor) where down tube plate mounts to fender well... etc. Also, anybody know of a 3.42 gearset for a Dana 44? I found one company but they discontinued them. Otherwise... I'm dropping off a 10-bolt for a full rebuild tomorrow afternoon. Much Thanks Last edited by Bino; 04-19-2008 at 10:04 PM. |
![]() Join Date: Feb 2000
Re: Building Rollbar
Welcome to the board. Here are some pics of my 70 K5's roll bar but I can't tell you if it would have been a dealer installed or aftermarket piece.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 04-19-2008 at 04:59 PM. |
Something like these-bolts to floor and wheel tub-3"
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Thanks for the quick reply with the dimensions. I now find myself a bit torn. I was thinking of doing a roll bar like you've got Yukon Jack, but I think it might be inconvenient for the rear passengers. I had planned on doing a bar like Green Monster and VTBlazer have on their vehicles (the topless thread is very useful when trying to nail down which roll bar is preferred). Would somebody mind posting some dimensions for that other bar as well?
jhow66, thanks for posting those pics, but I'm looking for a weld in style rather than a bolt-in. Thanks |
I don't think the rear bar causes any problems for rear passengers. My daughter did pump her head once getting to the rear but not sure that the top bar could be put anywhere else.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Yukon Jack's is the SMittybuilt bar. I had the Smittybuilt bar/cage conversion in my Jimmy, but the front part won't clear my STC top. Am going to build my own now that the soft top is installed. The bar itself fits no prob, it was the front legs that were too high for soft top.
#7 | |
The bar set up your hoping to recreate as a safety feature in your own blazer is 'NOT' a roll bar, your better off designing something that suites your own particular needs to 'BE' an actual roll bar. Glad to see your wanting to do this, it's a good idea for sure. |
Yes, that is a very good point. Thank you for clearing up my terminology. I figured "roll bar" most clearly conveyed the device I was looking into... even though it is a bit of a misnomer.
So, do you think that the style of "roll bar" that Yukon Jack is running would offer better roll over protection than the one that is on your blazer vtblazer? The mounting points on yours are pretty close, which could cause it to fold to the rear or front during a roll over. Obviously the only "good" roll bar would attach directly to the frame... I'm still on the fence about that one. While I do not plan on wheeling this vehicle hard, nor do I drive like a maniac, I would still like some form of roll over protection in the very unlikely even that it's necessary. I also need a place to mount 3 point seat belts... Thanks Last edited by Bino; 04-23-2008 at 10:07 PM. |
I doubt my style would do much in the way of protection in a roll over. This style just bolts to the floor and I could see it punching through the floor in a hard roll. Sure it's better than nothing but I too wouldn't consider it a functional roll bar.
I would think it would be unwise to attach shoulder belts to this style "roll bar". If you rolled and the "roll bar" pushed through the floor, you're going down with the bar!
Back in the sticks
Just for my own info, as mine is a bolt in affair as well, where would a "real" roll bar mount? I've seen the one that VT has in his, looks like it kind of rides along the floor and also mounts to the frame. Do they need to mount to the frame in order to really protect you? Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#11 | |
I built Kurt's cage (in the blue blazer) with a bit of help and it's tied into the frame in 6 locations, which also strengthens the frame itself. We determined that it would take a heck of allot to detach the chassis from the cage and it would make a far more stable platform. Most tend to connect to the frame, as it's very tough to model a break away cage pod. |
#12 | |
Don't know if he's seen your full cage handy work in the blue one. |
#15 | |
![]() You've got me thinking that I'll make some sort of hybrid bar. Probably a basic 4 point "sport bar" with frame tie-ins. This should really be all the protection I need, plus shoulder belt mounts. I'm guessing that about 2" OD with .120 wall tubing is pretty standard? |
#16 | |
