Re: Big block headers
NF65Fleetside, I bought a set of those from Summit. They fit great if you have an automatic transmission. I'm running a Muncie M21 4 speed. The problem is the stock clutch linkage. The #5 and #7 header tubes are in the way. I new this when i ordered the headers. I'm either going to modify the clutch linkage or cut and modify the header tubes. If the block huggers will clear, i will use them. The passenger side block hugger looks like it might hit the motor mount. The driver side looks like it will work.
Paul 1964 C10 SWB Fleetside-396/M21 4 speed 1957 Belair-283/M21 4 speed 1972 Camaro |
| Bookmarks |
