turbo enthusiast
does anyone know what the largest fuel tank that will fit in the stock location under the back of these burbs is? I don't care if its aftermarket or one you can get at the junkyard. I wouldn't mind even doing a little cutting and fabricating to make it fit. Mine is all beat up and the straps are rusting through, not to mention the fuel gauge doesn't work, so my tank will need replacing soon. Thanks.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
![]() Join Date: Nov 2007
Re: fuel tank
Mine had a crazy homemade one in it when i got it but it hung down too low.I got one out of a Jeep cheroke, it fit between the rails perfect.I think they come in two sizes.
If you get lost, come back and tell me where you are. 72 Burb, 86 1 ton crew cab dually. ![]() |
Re: fuel tank
My 72 Suburban has a 55 gallon tank. The previous owner made it.
turbo enthusiast
Re: fuel tank
a 55 gallon would be perfect! Looks like I will have to get one custom made then.
![]() Join Date: Mar 2008
Re: fuel tank
At $ 4.00 a gallon......... $ 220.00 ouch
![]() ![]() ![]() 1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
Re: fuel tank
1969 C10 Suburban, 396cid, Turbo 400, 9" F***, Disk brakes all around 1968 C10 Suburban, 350cid, 700R4, bent frame 1968 C20 Suburban, no motor, trans or interior (SOLD!) 1953 Packard Ambulance 1992 Caprice wagon |
Re: fuel tank
I will have one for sale, out of a '76 Burb, 40 gal. with the sending unit. no straps. this is the one that someone did a build thread on. Pm me if you're interseted and I'll get back to you when I'm back home Monday.
Al
1972 GMC Sierra 1972 GMC Super Custom Suburban |
Re: fuel tank
I am putting an ECE 27 gallon tank in my sub, have to move the rear crossmember though... kinda spendy but super nice, all stainless, sits up between frame rails, all baffled
55 gallons at 8.5 lbs a gallon is a lot of weight to carry around seems like, might hurt your gas mileage pretty good?
72 K20 Suburban 6.0L, 4L80, 4Wheel Disc Brakes, Hydroboost, In a Million Pieces(edit) A little closer to done |
Out of the carpool lane.
Re: fuel tank
Blue'72 has a 40 gal tank that I don't think he'll be using. I could get it as far south as Medford if you two would be interested.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
turbo enthusiast
Re: fuel tank
thanks guys for the replies. Not going to start this project just yet, but will let you know if something changes.
