Old 04-28-2008, 08:48 PM   #1
fastom
That's right, it's Copper!!
fastom's Avatar
Rear bumper gaps
I asked this on another topic but it was not answered.
I just installed the rear bumper on my truck and it has almost no gap between the bumper and the tailgate. I was concerned about it but I don't know if it's right or wrong.
I saw this picture on another topic and noticed the gap is much more than mine. I can't lower the bumper on my truck at all.
Please don't take this question as me putting this truck down, I'm not!! This truck is beautiful.
fastom is offline   Reply With Quote
Old 04-28-2008, 08:55 PM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: Rear bumper gaps
because the rear bumper brackets have two holes, one close to the bumper, and the second further in, you should be able to drill a new hole for the one further in to pivot your bumper where ever you want it to sit. i'm not sure, but i think there are two holes for the further bolt, so you may be able to make this adjustment without doing anything.
hope this helps.
IvelDesigns is offline   Reply With Quote
Old 04-28-2008, 09:11 PM   #3
wnc mountain
More hobbies than money!
wnc mountain's Avatar
Not that I have even looked at the brackets myself but maybe yours are installed on the wrong side upside down? Just a thought. Not sure if it matters or can be done.
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
Old 04-28-2008, 10:16 PM   #4
fastom
fastom's Avatar
The brackets only work one way. The problem is the bumper height. I'm able to move the bumper in and out using the holes.
Old 04-29-2008, 12:59 AM   #5
wnc mountain
After looking at mine my bumper is much higher than that one.
'72 Blazer project
Old 04-29-2008, 02:04 AM   #6
wnc mountain
Some pics of mine in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=289618
'72 Blazer project
Old 04-29-2008, 02:29 AM   #7
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
You want tight-clearance ?
Get yourself a farmer-bumper !!!!
Check out the shadow on the ground.
68shortstep is offline   Reply With Quote
Old 04-29-2008, 02:39 AM   #8
brad_man_72
the boat guy
brad_man_72's Avatar
wow you could loose a leg in that gap... my bumper is mounted like wnc mountain
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-29-2008, 04:03 AM   #9
fastom
fastom's Avatar
Great!! I won't worry about mine anymore.
Old 04-29-2008, 03:35 PM   #10
Orange
Licensed to Thrill!
Orange's Avatar
fastom - I think I misunderstood your question in the other thread...sorry about that.
So - is my truck wrong, or what's up? It's always been this way, and noone has ever said anything...
It used to have a step bumper on it, and then I put this one on it - perhaps I need some different mounts or something? It fits good though with relation to the filler panels behind the bumper.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 04-29-2008, 07:14 PM   #11
clos69
Its Topless Season!!!!
clos69's Avatar
Mine is in the same place as Orange's......does your tailgate opens and closes without rubbing against the bumper? When I installed mine it was sitting higher but I was able to lower it.
clos69 is offline   Reply With Quote
Old 04-29-2008, 07:22 PM   #12
fastom
fastom's Avatar
My tailgate doesn't hit, that was my main concern. The clearance is about an 1/8 of an inch when the tail gate is open.
Orange, your truck looks fine but the question going through my mind was is your right or mine. I guess it doesn't matter? Your truck looks good because the cross member is painted the same color as the rest of the truck. The cross member on mine is black. The bottom line is the gaps work on both trucks.
