Old 05-01-2008, 10:14 PM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Proportioning Valve. Do I have the Correct One?
I have done a swap from 6 lug Drums to 5 disk brakes in the front/6 lug drums to 5 lug drums in the back. My truck is a 69' with power brakes. Do I need to change the Proportioning Valve or am I okay with my current setup? Thanks, Harry
Update: Seems I may have to change the Master Cylinder also.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 05-01-2008, 10:30 PM   #2
myoldchevytruck
Re: Proportioning Valve. Do I have the Correct One?
ttt
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 05-01-2008, 10:35 PM   #3
cdowns
cdowns's Avatar
you need to change the prop valve to one from a disc brake truck because the residual pressure values are different fot discs and drums
Old 05-01-2008, 10:53 PM   #4
myoldchevytruck
does the year of the truck matter? Looks like 71-87 would work. How about a later year? (tons of later models in the bone yard) What about the master cylinder. Whatever truck I get the Prop. Valve from' can I use the same master cylinder? Thanks, Harry
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 05-01-2008, 11:36 PM   #5
steelhorse
steelhorse's Avatar
I believe you need the master cyl and prop valve.Not sure what years will fit,someone will chime in with that info soon.
steelhorse is offline   Reply With Quote
