Tasty Cakes!
What is this?
Is this right? What did the PO do here?? Found this in my door and several hidden spots around the body...
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
Commander Taco Bello
Re: What is this?
has the truck been painted? it looks like the PO welded up a hole in the door.
Re: What is this?
X2.... better than bondo!
Joe Last edited by chevychase; 05-01-2008 at 08:53 AM. |
Strange Cousin From The West..
Re: What is this?
I'll take a wild guess and say he removed the body trim and welded in the holes.
Tasty Cakes!
Re: What is this?
Yeah, I know it's welded, but what are the lighter areas that look like "worms"? Sorry for my ignorance, but I'm new to welding/body work.
Re: What is this?
Whatever it is, it shouldn't drip that way. Hah!!!
Re: What is this?
Prolly drilled hole for bondo to grab better.
Re: What is this?
You could look inside my doors, fenders, cab and bed and see the same thing, I removed the trim and welded the holes. If it is a good job, you and I will be the "only" ones that know it too.
Re: What is this?
Is that maybe sound deadener material that melted when it heat hit it?
1997 GMC Sierra Ext 1965 Mustang |
Re: What is this?
those "worms" are body filler. not the best way to do it, but I wouldnt worry too much about it...
Re: What is this?
maybe a dent was there or even a hole + dent, so the little holes are from a slide hammer, and the big hole got welded shut and the small ones bondo'd over.
Re: What is this?
Those "worm" like protrusions are definately bondo. I have seen that a hundred times on the backside of sheet metal that was pulled out by holes and a slide hammer.
Tasty Cakes!
Re: What is this?
Ok makes sense! The big hole was where the trim hole was (Shaffer4 guessed right!
Re: What is this?
I agree that it looks like body filler. Coat the weld and "worms" with something waterproof - maybe epoxy or at least rustoleum paint. Body filler is like talc and absorbs moisture if left uncovered it will start to blister.
