![]() Join Date: Dec 2006
heater box restore?
hey guys i was wondering if there was a way to fix the cracks in my heater box?i'm trying to clean and paint my engine compartment but that heater box is an eye sore? please help
ian |
![]() Join Date: Dec 2001
Re: heater box restore?
I can't remember the name of the stuff I used. It was like fiberglass in a tube.
Filled in cracks, sanded it down and primered heater box, then painted it body color. I think I got the stuff at Autozone. Dave
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
thanks do you remember the name?
Fiberglass repair kits are available at most autoparts stores. Just depends on how bad your box is & the amount of work you want to do.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Hit it with 40 or 60 grit sandpaper and apply fiberglass sheet with the resin. A kit might have what you need otherwise just buy a roll of fiberglass mat and the resin (2 parts). Cut the mat to fit, then mix the resin, coat the mat and apply. If at all possible cover the whole piece, so it will be uniform as opposed to looking patched, sand when hard and paint. Fiberglass repairs are really pretty simple, just wear rubber gloves and some sort of mask when sanding, those fibers are nasty and will make you itch (or kill ya if you breath them in!)
thanks alot i think i'm going to take the leap
