68 k20 4 speed swap to automatic
Hey buddy's will my stock 4 speed 1968 k20 trans fer case bolt up to a automatic transmision with mounts and drive line mod's.?? or what is the best way to to swap 4 speed for an automatic transmision????
Re: 68 k20 4 speed swap to automatic
The simple answer is no. The t-case adapter is different between the two and the 4 speeds output shaft has (I think) 10 splines and the auto has (i think) 30 splines. It will take some scrounging but the thing to do is find a trans, adapter and t-case and even driveshafts from an auto truck. If you get one with a 205 t-case your stock driveshafts might work if the overall length of the auto/t-case and manuel/t-case is the same. If you get one with a 203 t-case I think the driveshafts have to be shorter because the t-case is longer. If you get one with a 208 It has a slip yoke so your driveshafts won't work.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
I don`t believe the Rockwell case was ever mated to an automatic.I could be wrong.If they were it would be a rare find.Just find a complete auto/trans conversion.I`d buy a donor vehicle to get the whole deal.
I forgot that these had rockwell t-cases, so yeah the only way to do it is an entire swap. 4wd didn't get automatics until 71 before that all GM 4x4s were manuels.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made Last edited by sweet70beast; 04-27-2008 at 06:07 PM. |
`70 had TH350/NP205s.
Yep my K20 Suburban came with a 350/TH350/NP205 when it was new.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
I understand his point, though. There was never a Rockwell tcase behind an automatic. FWIW, I thought you could get an auto in a '69, because of the K5.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Born Psycho
![]() Join Date: Feb 2001
some of the early K/5s had dana t-cases so auto trans might have been an option.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
