05-05-2008, 11:57 PM | #1 |
60-66 VS 67-72 frame, the same?
I'd like to know if the swb frame on a 60-66 chevy are direct fit on a 67-72 body. Is it the same frame? Thank's
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually |
05-06-2008, 12:10 AM | #2 |
Re: 60-66 VS 67-72 frame, the same?
The '60-'62 chassis is quite different from the '63-'66.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
05-06-2008, 12:11 AM | #3 |
Ok but the 63-66 are the same?
05-06-2008, 12:20 AM | #4 |
Born Psycho
60-62 used torsion bars in front, cab mounts are different, front frame horns are different where the bumper bolts on. we did a lot of comparison when we converted a 63 2wd that belongs to my nephew over to 4wd. we were going to put it on a 69 swb 4x4 frame but i ended up finding him a 65 swb 4x4 frame and we put later running gear under it instead. disc brake dana 44 front, power steering off of a 73, SM465/205 combo from the same 73, 12 bolt rear from the 69 and brake booster/master cylinder from an 81. we built the chassis and had everything ready to go so he drove up in his 2wd on a friday after he got off work and drove home on sunday in a 4x4. it was a lot of work in a short amount of time but sure made a sweet little truck out of it.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-06-2008, 01:17 AM | #5 |
thank's jerry but i'm talking about a 2wd, front and rear suspension like to be the same on a 63-66 and 67-72.
05-06-2008, 01:20 AM | #6 |
i guess that kind of answered the question but not really. i was under the impression that except for cross member locations they were basically the same frame. so i guess what i'm getting at is which would be better to do, convert a 64 swb to fit under a 68 truck or chop the 68 lwb to use as a swb
05-06-2008, 03:01 AM | #7 |
Born Psycho
personally, i'd shorten the 68 frame since the cab mounts and frame horns are correct. the frame rails are pretty much the same except the bumper mount area.
