Old 05-03-2008, 08:58 AM   #1
sswitzke
sswitzke's Avatar
Brake question?
I bought my son a 66' swb stepside for his first truck. I replaced all the wheels cylinders, brake shoes all that I thought to replace I did. Well the brake pedal still goes to floor befor it stops. Any ideas?
sswitzke is offline   Reply With Quote
Old 05-03-2008, 09:43 AM   #2
64GMCHorsepower
Justified!
Re: Brake question?
I'm assuming you bled the brake lines?
That might be a reason......
Is it stock brakes?
If someone upgraded and did it wrong, it nmight not work at all....
good luck
Chad
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 05-03-2008, 03:02 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Brake question?
Are they adjusted properly? Try pulling up on the parking brake right before they grab and see if that makes the pedal better. If it dose the brakes will need to be adjusted more and if not you might still have air in the lines so try bleeding them again.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-03-2008, 04:56 PM   #4
poorboy
poorboy's Avatar
Re: Brake question?
Could also be a bad master if everything else checks out ok.
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 05-04-2008, 06:09 AM   #5
Dadsredwagon
Dadsredwagon's Avatar
Re: Brake question?
second the master cyclinder, auto zone here had a rebuilt one fro 16 bucks, Cheif Rocka herehas repalced his with a dual master cyclinder (drum/drum) you will have to run new hard lines, I hoep to do this in the future....
Dadsredwagon is offline   Reply With Quote
Old 05-04-2008, 04:43 PM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Brake question?
I would check the brake adjustment first...then re-bleed.
I usually set-up my brakes with a "one turn drag". Basically, tighten the adjuster all the way tight (this centers the shoes in the drums) then back-off a tooth at a time untill you get a slight drag which gives you a 1 to 1 1/2 turns on the wheel when you spin it....Applying the foot brake helps center things up too.
My 63' needs it brakes re-adjusted as well, now that I think about it
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-06-2008, 06:05 AM   #7
sswitzke
sswitzke's Avatar
Re: Brake question?
Thanks for the feedback, will give it a try next day I have off.
1967 Chevy long bed
1966 Chevy short stepside
