Old 05-06-2008, 06:59 AM   #1
ron19
5 lug rear axles
I'm junking a 76 Chevy big 10 that I took the front disc's off for my 65 (Note: I think the spindles are larger than a standard 1/2 ton but not sure)
My questions is, does anyone know if the rear 5 lug axles out of the 76 big ten 12 bolt rear would swap into the 12 bolt rear in my 65? That would save buying the axles out of CCP or somewhere else.
The rears measure close to the same, but not sure if they would actually install, has anyone tried this? I've got the scrap man coming tomorrow afternoon to get the truck, but I'll have him wait if they will work.
Thanks guys!
65' Chevy C10, Short Step
75' Chevy Big10 1/2, 1 time pull truck, now parts truck
02' GMC 2500HD 8.1L 4X4
ron19 is offline   Reply With Quote
Old 05-06-2008, 05:27 PM   #2
ron19
Re: 5 lug rear axles
Anybody got anything on this?
Old 05-06-2008, 09:06 PM   #3
1966-Suburban-V-8
1966-Suburban-V-8's Avatar
Arrow Re: 5 lug rear axles
Before the JunkMan cometh, I'd yank the whole rear axle out from under, but if you don' want to go there, at least pull the axles, and full brake sets. If you swap them with the full brakes, I think the axles may just work. But if it's long gone and you could have used 'em you'll be sorry....
Dan
1966 Chevy Suburban 'Gater - Shop Truck - 350/turbo 350
Power Steering, B&M Floor Shift, Dual side dump exhaust
Chrome Rally 6 lugs. (((XM)))tunes!
1965 Riviera 425 - Luxury Muscle - Fully Factory Loaded. All power, A/C, Custom Interior, Guidematic Dimmer, AM/FM - etc, etc
1966 Corvair Corsa Turbo - Factory Sport Model - Quick steering, F-41 HD suspension, Positraction, Tele Wheel.
1966-Suburban-V-8 is offline   Reply With Quote
Old 05-06-2008, 09:59 PM   #4
fchava
fchava's Avatar
Thanks guys!
I don't think this will work are the 76 rear is wider and the axle splines are different. You could always get yours redrilled for 5 lug.
fchava is offline   Reply With Quote
Old 05-06-2008, 10:16 PM   #5
leftcoast66
leftcoast66's Avatar
Yep, their I believe 3/4 inch on each side wider. I've got one under my 66 tho. Only issue is mounts for it, which isn't a big deal and then if your gonna lower the hell out of it, I ran into issues with it hitting the bed side at the spot welds.
leftcoast66 is offline   Reply With Quote
Old 05-07-2008, 12:22 AM   #6
billydonn
Council of the Elders
billydonn's Avatar
To repeat what others have said, the axles will not swap over. Replacement conversion axles are available or have yours redrilled and the center registers turned down. It is probably safer just to get the replacement axles. A 71 or 72 differential is a perfect swap except for the extra 1 1/2 width.
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 05-07-2008, 06:18 PM   #7
ron19
Thanks for the info guys, saved me many hours of disappointment. Also, Billydonn, your truck is my wallpaper at home, nice truck!
Old 05-07-2008, 08:09 PM   #8
billydonn
billydonn's Avatar
Talking Re: 5 lug rear axles
I am glad to help a gentleman of such refined good taste!
66 C-10 Stepside
Tremec TKO-600
