np205 compatability
Would an np205 from a 77 4 speed chevy be the same as my 205 in my 70 blazer? How much should I pay for one in good working condition. I'm planning on rebuilding mine but can't afford the down time on my truck so I'm looking for a cheap one to rebuild.
Thanks for the help Last edited by the_goat; 05-05-2008 at 12:10 AM. |
Re: np205 compatability
I did a search that listed 2 different 205s from 71-85, one with 10 splines and one with 27 splines, for a 4 speed and th350 respectively. Now I'm not sure which I have. Stock it was behind a th350 but has the stock adapter.
I appreciate it. |
I don't know the exact years and differences. I think the 77 will have the different splines and adapter bolt pattern.
Take a look on craigslist, you should be able to find an NP205 from a similar year truck without too much trouble. |
What trans do you have in your K5?
#5 | |
MidlifeCrisisUnderWay
Two things come to mind: 1) Mount surface (Race track or round) between engine and adaptor. 2) Spline count (ten, twenty-seven, or thirty-two). Race track mounting surface was on early models; round came on late models. Ten spline: early; twenty-seven spline: middle; thirty-two spline late. |
The 77 205 is a 10 spline and looks identical to mine but I haven't removed mine to look at the output shaft.
#7 | |
I think the ten spline came with a 465 attached to it. |
Thanks guys, I'll start looking for a 27 spline 205 then. Just curious did the next gen trucks use the same adapter between the th350 and 205 as well? I was getting hung up on the word "adapter" thinking it was a 10 spline with an adapter to run with a th350.
#9 | |
I have a Figure 8 205 here, with 27spline female input. I was going to use it on my build but went with a 32 spline instead. Last edited by FormerMember; 05-05-2008 at 06:01 PM. |
Very well, thanks guys, I almost bought the wrong one.
Well, there really isn't a wrong one... to make matters more confusing, you can swap inputs between the 27 spline and 10 spline t-cases. They use the same bearing. It does require a tear down of the t-case, but that's never a bad idea on something so old. I rebuild everyone I use.
The 32 spline input 205s use a 90MM bearing vs the 80MM bearing in the 10 spline and 27 spline cases. I have a ton of 205 parts here, let me know what you need. |
I'm going to attempt to rebuild my 205 but my truck is my dd and I don't want to have to hurry so I'm looking for a cheap 205 in my area to rebuild and then swap in.
This is a really good article:
http://www.fourwheeler.com/projectbu...ild/index.html I used this one for the pics: http://www.okcnetworks.com/bronco/205/np1.htm Be careful though, it's a Ford! |
Its lookin' like a Blazer!
Take a look on advancedadapters.com
The make new adapter housings, couplers and 205 cases. They've got pics of all of it. Might help you out. |
