Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-10-2008, 03:52 PM   #326
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: "Slowly but Surely" Big J's build thread...
Originally Posted by jaros44sr View Post
HAPPY BIRTHDAY
Seems like alot of work if it leaks, can you polish out the pits or are they deep
Thanks for the HBD. They're deep. It'd remove too much material. I found a new one for 89.00. I'll probably go that route.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 05-10-2008, 07:02 PM   #327
hgs_notes
GEARHEAD
hgs_notes's Avatar
I wonder if they make a sleeve for those like they have for the engine vibration damper?
hgs_notes is offline   Reply With Quote
Old 05-10-2008, 10:21 PM   #328
Big J
Big J's Avatar
I found some Speedi-sleeves but I'd have to have two, they'd sit where the seals ride. 45.00 each..... If it were cheap enough I'd go that route. Post up if you find something cheaper.
BAZINGA!
My Build
Old 05-13-2008, 04:19 AM   #329
Big J
Big J's Avatar
Got a little bit done today. Mainly getting it ready to take to the media blasting place. Filled in the hole in the top of the bedside and a couple other screw holes. Someone had cut up the tranny cover where the shifter goes through so I bent that back out and welded it up.
BAZINGA!
My Build
Old 05-13-2008, 04:23 AM   #330
49m
49m's Avatar
where you getting it media blasted and what are they charging.
My Rides
1969 Mustang gt coupe
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
2005 Ram 2500 Cummins
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=279831
49m is offline   Reply With Quote
Old 05-13-2008, 04:59 AM   #331
Big J
Big J's Avatar
Before I tell who and how much, lets see how it turns out....
BAZINGA!
My Build
Old 05-15-2008, 07:15 AM   #332
Big J
Big J's Avatar
Well I got it back from being blasted today. I thought I was done replacing metal..... I thought wrong. Talk about wanting to smash something. I was a bit upset, lol... I've since calmed down though. I reckon its best to find the other rust now than under my new paint in a few months. The top of the outside window frame, more bed area, tops of the bed rails around the top holes. On top of all the fun going on with that it actually started to flash a bit on the way home.... So I unloaded, at almost dark, busted out the gun and shot the epoxy. I had some light but not quite enough. First time using this particular gun too... Took me a minute to get used to it. Yep I've got some runs here and there. At least its covered and can't rust, lol.... I still have to use chemical stripper to do the outside bedsides. I didn't want to risk warping them. I'll post up some pics tomorrow. I didn't have time to snap pics.
BAZINGA!
My Build
Old 05-15-2008, 05:22 PM   #333
Yukon Jack
Yukon Jack's Avatar
What a bummer about the additional rust, but your right, better to find it now. Every project has set backs unfortunately. I hardly ever have anything go as smoothly as I think it should go.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-16-2008, 12:58 AM   #334
Big J
Big J's Avatar
Heres the good and bad.
BAZINGA!
My Build
Old 05-16-2008, 01:03 AM   #335
49m
49m's Avatar
Ive got some pieces of bed floor if you need it. Know will you say where you got it blasted and do you recomend it. I am going to get my truck done when I tear it down.
My Rides
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
My Build Thread
Old 05-16-2008, 03:17 AM   #336
Big J
Big J's Avatar
I've got some left over from the stuff I got from Jim but I might need more, lol... thanks for the offer. Still haven't found my box of extra pumps and pulleys.
For the sand blasting..... If your prepared to see the worst then go for it. If you think the metal is good enough then stick with a DA and chemical stripper..... I got it done at E&M Fabricating across the river in Madison. I do recommend them, he did a good job, nothing warped or blasted to nothing. Even got all the nooks and crannies underneath.
BAZINGA!
My Build
Old 05-16-2008, 03:21 AM   #337
Big J
Big J's Avatar
Well after staring at the pretty new white epoxy all day I'm in a much better mood. As for my new found rust, "Just a thing"......... Started tearing down one of my doors tonight. I rememberd having a issue of Classic Trucks with the order of removal, helped alot, lol.... I think after some tlc my vent wings will look nice.
BAZINGA!
My Build
Old 05-16-2008, 03:44 AM   #338
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
That tub does look good. Can't wait until mine is at that point.
BTW...nice work.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 05-16-2008, 12:51 PM   #339
vtblazer
vtblazer's Avatar
Hang tough J, like you said, better to find it now for sure.
You've gained skillz through all this, those rust spots got nuthin' on you.
vtblazer is offline   Reply With Quote
Old 05-23-2008, 05:32 AM   #340
Big J
Big J's Avatar
Alrighty then...... A fellow board member (family member, lol) donated a truck roof to the cause with a good top windshield piece. Its the same as the blazers. Not an easy thing to remove as its held on with 59 spot welds. I'll need to pick up some new bits before tackling the existing winshield frame. I also plan on using the truck top skin to make a hard bikini top. Picked up some nos trim rings from my favorite uncle last weekend too...... Heres the pics....
BAZINGA!
My Build
Old 05-23-2008, 12:33 PM   #341
jaros44sr
jaros44sr's Avatar
What's your thoughts on the inside pc., is it the same as a Blazer/Jimmy top rail?
Nice Uncle...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-23-2008, 12:54 PM   #342
vtblazer
vtblazer's Avatar
Nice Uncle...
No it's not, on a pick up it rolls right into the inner roof line.
Nice work with the spot welds J, blazer frame is waiting.
Old 05-23-2008, 01:09 PM   #343
Chevyman63
Chevyman63's Avatar
Wow...wish I had one of them there uncles like that.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 05-23-2008, 01:18 PM   #344
jaros44sr
jaros44sr's Avatar
Is there enough metal to make the bend up
SAFETY FIRST
AS usual, off topic
Jim
Old 05-23-2008, 01:38 PM   #345
vtblazer
vtblazer's Avatar
That's a good question...
Last truck cab windshield frame I looked at, it didn't seem doable but I wasn't faced with zero other option's at that time, so maybe I didn't look 'enough'.
Anything is possible when the need is there, you've got the skillz dude, make it happen.
You need another puzzle to figure out.
Old 05-23-2008, 01:50 PM   #346
jaros44sr
jaros44sr's Avatar
Ya, ny wifey calls me the problem solver, but it IS the last pc. of rust on the Jimmy
Thank you for the skillz comment, there is always a way, if the need and desire is there
SAFETY FIRST
AS usual, off topic
Jim
Old 05-23-2008, 01:53 PM   #347
jaros44sr
jaros44sr's Avatar
Ya, my wifey calls me the problem solver, but it IS the last pc. of rust on the Jimmy
SAFETY FIRST
AS usual, off topic
Jim
Old 05-23-2008, 02:22 PM   #348
Huck
Huck's Avatar
Jason, don't go nuts on small holes by cutting out if the structural integrety is there. You can seal with POR15 and bondo which will prevent future issues. Cutting and welding is fine when you have no other choice structure wise but if section is solid---no real need.
Huck is offline   Reply With Quote
Old 05-23-2008, 04:56 PM   #349
Yukon Jack
Yukon Jack's Avatar
I can't wait to see the hard bikini top - sounds very interesting!
Old 05-23-2008, 05:47 PM   #350
Big J
Big J's Avatar
I probably could go that route but I believe its worse than the pics look. Plus it will allow me to POR15 the inside when I get it apart..... I wish I could make myself go the bondo route.... All those spot welds are going to be a PAIN!
It shouldn't be very hard (we'll see ). The main thing my plan requires is that a person would have to be able to bolt the back side mounts to a roll bar. I'm using an aftermarket roll bar out of a truck and its got light tabs. So no problem for me.
BAZINGA!
My Build
