05-04-2008, 12:08 AM | #1 |
Registered Mail
Do you need BBC engine parts? I got a few really good parts!
things I have...and don't need anymore:
-freash set of BBC 781 heads (fully ported by machine shop-they flow awesome!), big valves (new stainless), new guides, seats (also by machine shop), all clean and hot tanked... ready to go! all you need to do is install the valves. (only thing not included is rockers). $700. -454 flywheel, only used to dyno an engine. make me an offer $. -two virgin 454 blocks, 2 bolt mains, 1 was hot tanked 1 wasn't. has matching bearing caps included. $200 each. one left -750 edelbrock carb, just rebuilt, not used since rebuild, bushings good and tight, mechanical secondaries, square bore. $120 i may have other parts but i'd have to look more...
'67 chev 496, lwb to swb, bagged - pro street project Last edited by smoknbarrels; 05-07-2008 at 11:52 PM. |
05-04-2008, 12:53 AM | #2 |
Moderator
Re: Do you need BBC engine parts? I got a few really good parts!
Do you have any pullies/brackets? Power steering set-up?
05-04-2008, 01:01 AM | #3 |
Registered Mail
I have some pullies... (since i used a new March system) but no power steering stuff sorry.
'67 chev 496, lwb to swb, bagged - pro street project |
05-04-2008, 01:10 AM | #4 |
Moderator
I am looking for crankshaft pullies (2 groove for A/C) and the single groove add-on for power steering. Also looking for the waterpump pulley (2 groove also for A/C) For a 1972 truck with a 402, short water pump.
05-04-2008, 01:25 AM | #5 |
Registered Mail
I have (if i remember) two crankshaft pullies both 2 groove, a water pump pulley (not sure if it's for a long or a short - how can I tell?) (i think it's two groove - i'll check this weekend)
'67 chev 496, lwb to swb, bagged - pro street project Last edited by smoknbarrels; 05-04-2008 at 01:27 AM. |
05-04-2008, 01:36 AM | #6 |
Moderator
Parts numbers off the pullies will help the most in determining if they are the ones I need.
05-04-2008, 05:35 AM | #7 |
Registered Mail
will get #'s for ya this weekend!
05-06-2008, 04:51 AM | #8 |
Registered Mail
I took photos of the part numbers but for some reason only one turned out?? stupid flash.. anyway, the first two are water pump pullies, and the last is a crank pulley.
then heads photo then a photo of my virgin twins! not sure why there is a funnel in one of them?
05-07-2008, 11:54 PM | #9 |
Registered Mail
tt
05-08-2008, 01:05 AM | #10 |
i would like a better pic of heads 1 of intake port and turn the other head around and get exaust port while your at it what size valves did you cut these for thanks pm me the pic if ya want
nickle and dime Last edited by royo; 05-08-2008 at 01:06 AM. |
05-10-2008, 06:25 PM | #11 |
Registered Mail
i'll get photos for ya this weekend..
