Old 05-10-2008, 02:00 PM   #1
bamabaxter
bamabaxter's Avatar
Question What side is the oil dipstick?
I know this sounds odd but what side of the motor should the dipstick be on if it is a 72? Don't worry I am not confused about how to check the oil but a couple of my friends said it was odd that my oil dipstick was on the passenger side for the early year model. I am just curious also. If it supposed to be on the driver side then this would confirm that this isn't the stock motor which I was almost sure of anyway. If anyone has any info I'd appreciate it a lot.
'72 Chevy C10
383, 700r4, 3.73's
A little rust never hurt anyone. I consider it weight reduction.
bamabaxter is offline   Reply With Quote
Old 05-10-2008, 02:11 PM   #2
70GMCer
70GMCer's Avatar
Re: What side is the oil dipstick?
I believe all the dip sticks for our trucks are on the drivers side, for sbc engines. Others will post about it....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-10-2008, 03:28 PM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
all sbc dipsticks were on the driver side until 84 (IIRC). you have a replacement engine.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-10-2008, 06:42 PM   #4
berencam
berencam's Avatar
its 86 on im pretty sure thats on the passengers side.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 05-10-2008, 07:36 PM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
IDK bout the year change, but I believe 305s had them on the passenger side also
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 05-10-2008, 08:49 PM   #6
truckdude239
truckdude239's Avatar
my 305 from a 78 is on the driver side also
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-10-2008, 10:08 PM   #7
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Chevy II and nova engines had goofy oil pans and passenger side dipsticks.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 05-10-2008, 11:30 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I was thinking it was 74 or so when they went to the passenger side, but either way, 67 - 72 are supposed to be on the drivers side
Old 05-11-2008, 12:04 AM   #9
old Chevy guy
old Chevy guy's Avatar
IM not sure what year it is that changes either but I just finished a moter swap on a 84 K20 and the old moter was on the passengers side but the doner moter was on the drivers side and it was a hassle,I had to get diffrent exhaust manifolds because the ones on the 84 dumped right where the dipstick goes on the drivers side. I had to buy a oil pan gasket for a 78 to get one that had drivers side stick,79 did not.What color is the moter in your truck, that is a quick indicater of year.67-72 should be chevy orange.
old Chevy guy is offline   Reply With Quote
Old 05-11-2008, 12:14 AM   #10
clean71
clean71's Avatar
IDK but on my zz4 block it says there is a port on both sides but the only one I've found is on the passenger side and lower than the standard ds one. Sucks cuz I bought the short billet dipstick before I figured it out.
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
Old 05-11-2008, 01:28 AM   #11
allen123
It'll buff out
allen123's Avatar
my engine is a 85 and its on the passenger
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 05-11-2008, 03:20 AM   #12
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
either 79 or 80 they went to passenger side dipsticks, some mercruiser blocks had provisions for both sides of the block, and the mid 60's c60s with v8s had a plug on the drivers side and just had the dipstick in the pan opposed to going through the blocks, there are tons of variations
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 05-11-2008, 04:17 PM   #13
bamabaxter
bamabaxter's Avatar
The motor is Chevy Orange. I talked to the previous owner and he thinks tha thte motor came out of a later model chevelle. Would that make since for the dipstick to be on the passenger side. Sorry for not replying sooner. I was admitted to the hospital yesterday.
'72 Chevy C10
383, 700r4, 3.73's
Old 05-11-2008, 04:32 PM   #14
Been there done that, except from the opposite perspective
The tubes are also different size diameter between the two sides also.
Old 05-11-2008, 04:35 PM   #15
bamabaxter
bamabaxter's Avatar
My dipstick tube definitely doesn't seal well. Is there supposed to be an o ring on it or something?
'72 Chevy C10
383, 700r4, 3.73's
Old 05-11-2008, 07:25 PM   #16
Walts_restoration
it could of been painted orange too. is there a provision in the block?
