Old 05-12-2008, 04:18 AM   #1
vern350
like a rock
vern350's Avatar
87 transmission interchange?????
Looking to change out the transmission in my 87 longbox. It is a 700R4. No longer works, and have several other transmissions which are alos 700r4s. Which will work? Can i change the tailstock?
I know theres something to do with shaft lengths or something along those lines. Finally got it running again and now the transmission doesn work. I drove the truck before winter and then it sat and it didn't run or drive. Now it runs, but doesn't drive.
700r4 from 87 chevy 4x4
700r4 from 88 chevy 2wd
700r4 from 87 iroc-z camaro
Any help is greatly appreciated.
Vern
vern350 is offline   Reply With Quote
Old 05-12-2008, 04:45 AM   #2
SanitysBane
Re: 87 transmission interchange?????
The one from the camaro will bolt up just fine, will need to change the speedometer gears. I think with the 4X4 you have to change the output shaft inorder to use the 2wd output tailhousing.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 05-13-2008, 06:16 AM   #3
vern350
like a rock
vern350's Avatar
thanks.....
