Old 05-13-2008, 04:14 AM   #1
prg machine
prg machine's Avatar
doors and seals
well I succesfuly got the doors hung.. ( finished the drivers side today). I temporarily installed ( tacked up with masking tape) a door seal that I purchased from Brothers and the fit seems good, it just requires a push to close entirely the last 3/16 of an inch or so. So the question is...... should the door seals be installed before the foor mat I ssume? I am using the rubber mat with felt backing.
Thanks again
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 05-13-2008, 05:39 AM   #2
463
463's Avatar
Re: doors and seals
Yes: and no, yes if your careful with the mat install. no if your not (mat draging in over the unprotected seal may rip or tear the door seal) 463
Trueman
463 is offline   Reply With Quote
