Old 05-14-2008, 07:06 AM   #1
salazar44
65 - Chevy C10
salazar44's Avatar
inside bed ideas
The inside of my bed is pretty tore up. At this time I am not replacing any panels and I wont be putting in the wood slats. I planned on painting the inside with Herculiner but dont know how to handle the bottom of the bed.
Does anyone have ideas or examples of something different then original?
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 05-14-2008, 02:02 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: inside bed ideas
do this!
Old 05-14-2008, 02:03 PM   #3
jonzcustomshop
1961 crewcab
...... just kidding, how about a steel floor out of a 73-87 cut to fit?
Old 05-14-2008, 03:06 PM   #4
ChopperDr
My dad let me in on a little farmers secret when I was young. A simple sheet of plywood would form a nice bed and cover rusted or rotted out areas. After a while in the elements they weather nicely.
Chopper
ChopperDr is offline   Reply With Quote
Old 05-14-2008, 04:30 PM   #5
Rogue 64
Ol' Blue Viking
I have seen a 65-66 C-20 with a factory corrugated floor.
anyone know the RPO for that?
I may put a late model floor in mine.
Driving Paw-paws truck into the Sunset!
Rogue 64 is offline   Reply With Quote
Old 05-14-2008, 04:36 PM   #6
salazar44
65 - Chevy C10
salazar44's Avatar
pics anyone? anyone besides jon? haha... jk jon!
VIC
Old 05-14-2008, 04:50 PM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
plywood is going to be the easiest. But if you do it you should take the old out and remove your wheel tubs and put it under them. It is a big job if you don't know how to do it. If you just lay in on top of the old, water can get trapped under it...
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-14-2008, 05:03 PM   #8
Anthony Fremont
Anthony Fremont's Avatar
Somebody put a 3/16 - 1/4" steel plate in mine (66 GMC Fenderside LWB) at some time in the past. They welded all along the end by the tailgate and tacked around the edge for the rest of it. I have to say that it fits nice, but I want it gone. Come get it if you want, most of the tack welds are already loose. Remember, it's for a long bed so you can trim it for a custom fit.
Anthony Fremont is offline   Reply With Quote
Old 05-14-2008, 07:56 PM   #9
SIR
SIR
SIR's Avatar
if your going to do it.... do it good,the first time,think about that spray-on stuff once it's on there that's pretty much it ...just my 2 cents worth.
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 05-14-2008, 08:25 PM   #10
salazar44
65 - Chevy C10
salazar44's Avatar
Anthony... that would be quite a drive!
Sir... Your bed is VERY spiffy. Someday I hope! I actually dont mind the herculiner on the inside of my bed. Besides if I was going to do it right I would get all new panels first. Its just not within my budget at this time.
How thick should I get the plywood to be consistent with the original wood. Right now the wheel tubs are pretty much floating because I removed all the old wood and I want it to be the same height. Thanks guys!
VIC
Old 05-14-2008, 09:01 PM   #11
Chevy Fleetside
3/4". And if you can get the pressure treated but if you were to do that it would only be a few more bucks to put real wood in. You will need 2 sheets of 4x8 ply and will have to do some cutting. Just make the seam down the middle. If you were closer I would help you out with it. I would make you get real wood though. I am a carpenter by trade. This was my stepside bed done with birch that I bought at Home Depot for $175..
Old 05-14-2008, 09:34 PM   #12
salazar44
65 - Chevy C10
salazar44's Avatar
I have seen the plans online to do your own wood slats. I forgot where though. However, I dont have any wood cutting tools to do such a thing.
Otherwise the wood kit cost $407!
Polished Stainless bolts/strips = $270
Cadium/SS bolts/strips = $105
That adds up to $More.ThanIhave LOL.
Now if I could buy the wood and cut it myself it would be more reasonable.
So, I think I will pick up some plywood in 3/4" and buy the cheap bolt kit. Its not what I want... but it will do for now.
Then I can probably use some type of strip down the middle to cover the seem??
VIC
Old 05-14-2008, 11:52 PM   #13
jonzcustomshop
1961 crewcab
If you have the original bed strips , maybe just bolt them on top of the ply wood- they wouldnt sit flush, but would look right.
however, if you are going with 2 pieces of plywood, with a seam down the middle , and you are going to spray the rhino liner over it, I would run a thin piece of sheet metal screwed to the underside to hold the two piecs together, and I would put wood glue in the seam.
Old 05-14-2008, 11:54 PM   #14
salazar44
65 - Chevy C10
salazar44's Avatar
hah! that would be pretty sneaky! to still run the strips on the plywood! thats why ur truck looks like it does because you are very artistic and clever!
VIC
Old 05-15-2008, 12:52 AM   #15
muddpile
muddpile's Avatar
I'm in the minority with this look, but it did fix a rough bed floor
But in all reality, I like the plywood with the strips idea. I've seen it done before and some times it is hard to tell it from the actual hardwood.
muddpile is offline   Reply With Quote
Old 05-15-2008, 06:50 AM   #16
jhow66
jhow66's Avatar
Alum. step plate: (treated plywood underneath)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-15-2008, 07:37 AM   #17
NF65Fleetside
NF65Fleetside's Avatar
aye Vic, 1gearhead here can hook it up on some sick diamond plating for your truck if you want to go that route. He lays down some good work. Or you can go the temp route with me and just get a thick sheet of plywood cut to demensions and rough it out til were ball'n!
NF65Fleetside is offline   Reply With Quote
Old 05-15-2008, 02:18 PM   #18
scotts62
One day...
scotts62's Avatar
Back before i bought my bedstrips i used a sheet of plywood and cut one inch pieces as the strips then stained everythong on both sides with tranny fluid, it was stylin on a cheap budget in highschool!!!!
Scott
93 crew cab build
Project 62
Old 05-15-2008, 03:47 PM   #19
63 & 64 Bowties
and a few others
I can tell you a cheap route that I did with a 66 stepside I had a few years ago. Go to home depot and get two sheets of T1-11 (tee one eleven) If you're a non-carpenter like me and don't know what that is, it's the 5/8" used as siding with about 3/4" grooves cut into the sheet about every 6" or so. It has kind of a rough finish. I cut it to size (only needed one sheet for the stepside, you'll need two for your fleetside) then belt-sanded smooth, coated with marine spar varnish ( 2 or 3 coats) then with an artist's brush I painted inside the grooves with flat black rust-oleum. I painted the grooves AFTER the varnish to cut down on bleed over. It was cheap and I think it looks a lot better than just plain plywood. The painted grooves kinda give the illusion of bed strips. Sorry I don't have pics, the trucks been gone for a while.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
Last edited by 63 & 64 Bowties; 05-15-2008 at 03:50 PM. Reason: felt like havin' a peanut butter & jelly sandwich
63 & 64 Bowties is offline   Reply With Quote
Old 05-15-2008, 03:54 PM   #20
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks a good idea...you could even fill the grooves with some strip if you wanted to.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
