05-15-2008, 03:43 AM | #1 |
Clutch Linkage Problem
Posted this in Drivetrain but I thought I might get a little more feedback here
I have a Munice SM 465 that I am putting in my 67, today I noticed the clutch fork comes off the little pivot point, Is the fork suppose to stay on there tight or is it suppose to come off easy like it is. If this is a problem,How do you fix it?
1967 c-10 longbox project, check it out in projects 1969 c-10 parts pickup, twisted frame Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block Last edited by oldsmobilekindofguy; 05-15-2008 at 03:44 AM. |
05-15-2008, 03:48 AM | #2 |
Nothing to see here.....
Re: Clutch Linkage Problem
the z fork mounts to the engine via a bracket that has a ball welded to it and the z bar has two spherical plastic washers around it.
the frame mount is basically the same, but make sure it stays tight against the frame bracket, or it will get very, very loose. this bracket takes a lot of repetitious movement and does get worn. you may take a pic for us to help you figure it out.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
05-15-2008, 04:14 AM | #3 |
I could try to get a pic but connected to the motor it is gonna be hard to get a decent picture
1967 c-10 longbox project, check it out in projects 1969 c-10 parts pickup, twisted frame Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block |
05-15-2008, 04:30 AM | #4 |
Are you describing the frame mount or the engine mount?
05-15-2008, 04:33 AM | #5 | |
Bloo
i think he's talking about the ballstud inside the bellhousing, that the throw-out fork rides on. your throwout fork is supposed to have a "spring clip" inside it that holds the fork to the ball. i got mine at www.classicparts.com
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
05-15-2008, 05:18 AM | #6 | |
that sheds a bit more light on it. I thought he was talking about the z bar....
05-15-2008, 07:00 AM | #7 |
The fork that goes in the bell is not especially tight it just kind of pops on and off.Theres two spring metal fingers that clip it on to the pivit ball
05-15-2008, 07:25 AM | #8 | |
Bloo
here ya go, this goes in a groove in the back of the throwout fork
05-15-2008, 04:33 PM | #9 |
thanks all that is exactly what I needed to know, sorry about the misinformation but I didn't really know how to explain my problem
thanks
