Old 05-15-2008, 04:54 PM   #1
nac593
rebuilt heater doesn't work
I took it all apart, cleaned it, and replaced the heater core. Before the fan worked, now it doesn't. It has 12v and the ground is good. I checked the switch in cab on heater box (themal switch?) on pass. side. It has 12v. I wanted any ideas before I take it apart because I used gasket sealer when I put it together.
nac593 is offline   Reply With Quote
Old 05-15-2008, 05:46 PM   #2
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Re: rebuilt heater doesn't work
Get a couple short pieces of wire and run straight from the battery to the fan with a hot and neg. If it works, then you have to trace it backwards.
Check the fuse. But more then likly its a bad ground. I had to get a drimal tool and take it to the metal on the cab and the fan to get the gound to work.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
