Old 01-30-2003, 10:03 PM   #1
CPNE
Resident Curmudgeon
CPNE's Avatar
comparison of 305 V6 and BB Fan Shrouds
Found these on my computer. 305V6
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-30-2003, 10:04 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
bb
Old 01-30-2003, 10:04 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
v6
Old 01-30-2003, 10:09 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
bb width
Old 01-30-2003, 10:10 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
v6 diameter
Old 01-30-2003, 10:11 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
bb diameter
Old 01-30-2003, 10:27 PM   #7
GMC71k20
thanks for doing that, now ill have trust in a 305 shroud if i ever put it infront of a BB.
GMC71k20 is offline   Reply With Quote
Old 01-31-2003, 12:14 AM   #8
Rod
Are the width's the same... can't read the numbers on the BB one. Rod
I think I might own one of those exact ones...BB.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-31-2003, 07:58 AM   #9
CPNE
Resident Curmudgeon
CPNE's Avatar
Rod, the diameters and all dimensions except depth are identical. The depth of the bb shroud is about 1/2 inch bigger as shown in the 3rd and 4th pics
Old 01-31-2003, 12:30 PM   #10
Erl
Erl's Avatar
That is very interesting. I need a new shroud for my 305V6. My 67-70 GMC factory parts manual shows part number 3924932 for the K2500 305V6. For the 396 big block the part number is the same. This means that the early BB shrouds are the same as the 305V6, but the later years were different (thicker approx 4 inch)? The 305V6 shrouds were also smaller for a 1/2 ton. So there are two sizes of shrouds for the 305V6. Some of the shrouds have a part number molded in, can you find it on your two examples?
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 01-31-2003, 12:43 PM   #11
CPNE
Resident Curmudgeon
CPNE's Avatar
Erl, sorry both shrouds are long since sold. I can tell you that the v6 shroud was off a 67 GMC camper special from which I can only assume it was a 3/4 ton as I never had entire truck just a few parts. The bb shroud pictured is off a 72 Chevy 3/4 ton and is approx 1/2 inch wider in depth
