Old 05-15-2008, 11:06 PM   #1
jdurant
exhaust question
Right now my Blaxer has a single flowmaster with a dump for exhaust. Sounds good, everything is fine until I roll all three windows down. Then I get a whole lot of exhaust fumes circulating through the truck. Since it is no good dumped, I guess, I would like it dual and coming out at 45s between the rear bumper and tire. I'm not sure if there is enough room to make that look right with the fuel tank.
Let me know what you guys have done.
Thanks. pics would help.
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 05-16-2008, 02:59 AM   #2
GG_Blaisdell
Re: exhaust question
I also like the idea of the 45 degree pipes at the rear. Saw a Ranger with a nice dual set-up like that and think it would compliment the Blazer well. I wonder if the quasi-out the back location would cause any problems with the read window rolled down? Anyone have ideas or experience with something like this?
GG_Blaisdell is offline   Reply With Quote
Old 05-16-2008, 03:05 AM   #3
kevinr1970
Heres the way I understand it to work.
With all three windows down, when the air passes over the door windows it creates a vacuum. The vacuum pulls air IN through the rear window and it gets sucked out the door windows.
So regardless of where the exhaust is located it will still get exhaust as the exhaust swirls around behind the truck when moving. Thats why the back windows get so dirty.
Conversely, if you keep the door windows shut but have the rear window down and then open your floor vents (non-AC trucks) or set your HVAC control to "vent" it will provide massive amounts of air.
In theory...
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 05-16-2008, 05:21 AM   #4
68Timber
I know the pieces fit
68Timber's Avatar
My last Blazer was 45'd on each side, that's how I plan to do this one. It looks good and there's enough room to do it.
Old 05-16-2008, 04:26 PM   #5
tobiahr
tobiahr's Avatar
If you are trying to keep exhaust from coming in you have to keep the rear window shut. I've had both the the 45 degree pipes, rear dumps (came out beside the license plate) and even a set of side pipes that dumped in front of the rear tire. With all of these i still had problems with exaust fumes with the rear window down and strangely enough problems with the top off with the rear dumps. I have also had fume problems with leaking weatherstripping on the rear gate with rear dumps. Currently going with 45 degree pipes to avoid as much as possible. IMHO they look better too.
tobiahr is offline   Reply With Quote
Old 05-16-2008, 06:04 PM   #6
tvblazer78
Low & Fast!
tvblazer78's Avatar
All of this is all right, if you run it in front of the back tire and have the top off it works well. That is just how the blazers are...
tvblazer78 is offline   Reply With Quote
Old 05-16-2008, 09:16 PM   #7
jdurant
That is what I was afraid of. That really sucks, since one of the best percs of the Blazer is to ride with all three windows down--the circulation is perfect and the turbulance is low, you can still hear your stereo really well. I guess I will see if it is any better with 45s when I get around to it.
Joseph
87 Turbo Buick
87 GMC Sierra SWB
