1987 van rear end
I was wondering if the whole rear end from a Chevy 1987 van will bolt up under a 1988 chev 1/2 ton. Are they the same rear end housing ?
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride Last edited by chevy88; 05-13-2008 at 03:08 PM. Reason: clarification |
Re: 1987 van rear end
everything is the same but the van axle is narrower so, no, it wouldnt work.
-Jake 1962 C60 261 I6 5+2spd I like to be different Interior- Puke green dash, brown vinyl seat from an 87. Exterior- Rust 1993 Full Size Blazer 4x4 Stock for now.If you have a truck everyone is your friend. When they need to move. |
6.0 powered square
what I would do, if every thing bolted right up then add wider wheels and do a mini tub
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
![]() Join Date: Mar 2000
I don't know about the 87 but I have a 91 van with a 14 bolt and it is way wider than the 10 bolt on my 92 RCLB 4 x 4
Saskatoon, Saskatchewan Canada |
Maybe it was wider? I dont remember which it was but I do know that it was either narrower or wider. I thought it was narrower.
| Bookmarks |
