Old 05-17-2008, 09:36 PM   #1
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
HEI question
When replacing the coil in my HEI cap, I don't have a wire that goes from the ground on the coil to the ground terminal for the module. The coil just grounds to itself.
Is this a problem?
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 05-17-2008, 09:49 PM   #2
michael bustamante
michael bustamante's Avatar
Re: HEI question
I believe coil grounds when you run the hold down screws, but its been awhile since I opened my cap
1967custom
michael bustamante is offline   Reply With Quote
Old 05-17-2008, 10:03 PM   #3
BarryB
BarryB's Avatar
Re: HEI question
You have three wires coming out of the dis, and go to the coil, I am pretty sure the coils grounds itself thru the control module. It has to complete the circuit in order for the module to work. That's my thoughts for what there worth.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 05-17-2008, 11:32 PM   #4
Wrenchbender Ret
Re: HEI question
There is a terminal that goes under the coil to the center term on the connector where the dist plugs in. Some early models used a wire. This is often left out when someone replaces the cap. It must be there or serious component failure will occur.
Wrenchbender Ret is offline   Reply With Quote
Old 05-18-2008, 03:15 AM   #5
LONGHAIR
Re: HEI question
Yes, you need that.
I really have no clue as to why someone would leave it out, but they do. Apparently it will run (at least for a while) with out it, but I have never seen it. Every one I ever worked on was because it wouldn't start.
LONGHAIR is offline   Reply With Quote
Old 05-18-2008, 05:38 AM   #6
old Chevy guy
old Chevy guy's Avatar
Re: HEI question
After putting a new intake gasket on one of the many chevy vans Ive had I put a new cap ,wires and plugs in. Without realizing I left that little ground strap between the coil and the plug out. The van ran but when I
test drove it it didnt seem to run quite right so I drove past the driveway and drove it further in the other direction,all at about 2 in the morning on a work night. Well when I went to turn around again the truck stalled and would not start again,I tried until the battery was dead. It turned out to be the darkest night ever,me without I light,broke down next to the cematary 2 miles from home 230 am.It was so dark I could only find my way by following but barely seeing the yellow lines in the center of the road.Where I live there are few street lamps ,mostly only at corners,and the houses are few and far between!Needless to say when changing a HEI cap I never forgot that ground again! By the way it started right up and was fine when I fixed the ground in the daylight the next day
old Chevy guy is offline   Reply With Quote
Old 05-18-2008, 06:57 AM   #7
jhow66
jhow66's Avatar
Re: HEI question
The ground strap looks like this:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-18-2008, 07:04 AM   #8
boundstaffpress
Re: HEI question
Thanks guys.
Are these available at checker/napa?
:Edit: They are. Just found them here.
Justin
Old 05-18-2008, 11:22 AM   #9
El Jay
Gone to greener pastures
Re: HEI question
Did you "whistle past the graveyard?"
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-18-2008, 03:32 PM   #10
LONGHAIR
Re: HEI question
It has been years since I worked on one with the ground missing, but I don't remember one starting by just putting the ground back on. I seem to remember it always killing something else. Module? coil?
Old 05-18-2008, 05:18 PM   #11
boundstaffpress
Re: HEI question
I lost a coil. It may have been from old wires and rusty coil support, but I suspect that I have also lost my module now. I have a new one. I should have just bought a whole new skip white unit in the beginning.
Justin
Old 05-18-2008, 05:32 PM   #12
LONGHAIR
Re: HEI question
That's a live-and-learn thing. From what I have heard, his stuff is great, and the cost difference would be minimal. Oh well, next time
Old 05-18-2008, 10:22 PM   #13
boundstaffpress
Re: HEI question
I ended up making a ground, as they were out at the parts store, and the salvage yard was not open.
I did get the engine to fire up, but I still have a weak spark on #5, #7 and #2. May have to order some new plugs.
Justin
