Old 01-31-2003, 12:46 AM   #1
68gmcjon
Got earplugs?
68gmcjon's Avatar
battery/electrical?
when i go to start my truck it just acts like the battery is dead, so i try to jump it. No luck. the jumper cables are good. I hook up the battery charger and turn on my lights, with the charger hooked up the lights work fine, but without they don't even shine. What's wrong with my truck?
1968 GMC
Original A/C, bucket seats, PS,PB
396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression
Alltogether 411HP and 446ft/lbs
Dana 60 w/ 3.54 gears
Turbo 400 tranny
Why would you have anything other than a big block? HAHA
68gmcjon is offline   Reply With Quote
Old 01-31-2003, 02:33 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Lots of things to check.
1. Are your battery posts & terminals clean and tight?
2. When you try to jump start do the lights work?
3. When jump starting, is the nurse vehicle running? With a dead battery, this makes a big difference.
4. Does the starter engage, click or grunt?
5. What happens when you run the charger overnight? If you haven't, hook it directly to the battery posts.
I am guessing either a bad battery or bad connections. One thing you can do is to charge the battery overnight, then take it to a parts store or Wal-Mart and have them check it. They'll do it for free in hope of selling you a new battery.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-31-2003, 04:28 AM   #3
barn9
Half a bubble off!
barn9's Avatar
Jon, sounds like a bad battery from the description. O'Reilly's will check it for you, and they have about the best prices here in Winfield when it comes to batteries. PM me if I can help you.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 01-31-2003, 04:46 AM   #4
Hooter
My other Love
Hooter's Avatar
Bad battery or bad connection on the starter, or a heavy drain on the system somewhere
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-31-2003, 07:14 AM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
This is interesting to me as my battery flattened itself out over the Christmas break when I didn't use my truck, so i think it's on the way out. What do you reccomend as the minimum spec for a battery for a truck with a fairly standard 350? AH and cranking amps.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 01-31-2003, 08:29 AM   #6
68gmcjon
Got earplugs?
68gmcjon's Avatar
Hooked the charger directly to the posts last night and it started right up this morning
1968 GMC
Turbo 400 tranny
Old 01-31-2003, 09:22 AM   #7
minibike
minibike's Avatar
I just had a grounding problem with my starter. I connected the negative jumper directly to the housing on the starter, and it fired right up. After figuring it out, I put the grounding cable on one of the starter bolts, to ground the engine.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 01-31-2003, 10:09 AM   #8
Tynee
I miss this truck.
Tynee's Avatar
Something to think about when having a parts store check your battery/ electrical system, They ARE trying sell you parts. I've never had them test anything that didn't come up needing to be replaced. Now, whether or not there new parts fixed the symptoms or not is a different story. On the bright side, it also comes up needing to replace whatever you are having them test when the part is still under warranty.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 01-31-2003, 11:44 AM   #9
Fred T
Cantankerous Geezer
Fred T's Avatar
Sounds like a bad connection between where you were connecting and the battery. I would start by cleaning the battery posts and terminals, if you haven't done so already. Check it again after cleaning, then see if you alternator is charging.
Fred
Old 01-31-2003, 03:51 PM   #10
6869704X4
The biggest one that will fit. hehe I know it gets pretty cold in England.
The batteries that came in these trucks were only about 450CCA (if my memory is correct)unless you got the heavy duty one.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 01-31-2003, 08:05 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
You can save yourself a lot of trouble and headaches if you will periodically remove the cables from the battery and clean the terminals of the battery AND the ends of the cables where they fit onto the terminals. Use NOCO pads under the ends to help minimize corrosion, or use some of the spray stuff that some parts stores sell to do the same thing.
If your cables ends are bad, and you are using the type that clamp on the old cable, make sure the wire of the cable is clean and sufficient to allow current to pass thru the connection. Cables with the ends made onto them, are better, but sometimes you just have to "make do" when funds are short or when time doesn't permit a more extensive repair/replacement.
If you see that electrolyte is boiling out of the battery, a mixture of baking soda and water, painted on the surrounding metal, will help to neutralize the acid. You should also wash the top of the battery, and you can use the mixture of soda and water on it BUT BE CAREFUL! If you get any of the soda mixture into the cells of the battery, you could shorten the life of the battery.
Also, batteries that are being charged, give off hydrogen sulfide gas....a gas which is explosive. The gasses from a battery can explode with sufficient force to do extensive damage to your vehicle or harm anyone nearby. Don't use a match, or a lighter, to look at the electrolyte level in a battery. Use a flashlight (Okay, LippyP....a torch) to check the level. If your battery has the "eye" indicator, it should be green, if fully charged. If it is black, the level of acid is probably low.
Member Nr. 2770
