Old 05-20-2008, 01:53 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Body mount question.
Ok heres what I got I have a 69 3/4 ton frame with 72 cab and a 68 bed and front clip. By all rights the 3/4 ton cab mounts should be the same for the cab,right? The cab and bed seem to line up fine however the front clip is way off its like the bushings are too tall for the core support. Anyone have any info on this,anysuggestions or comments?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-20-2008, 02:02 AM   #2
whatnow123
whatnow123's Avatar
Re: Body mount question.
I don't know the answer to your question... but MAN do you have a lot of posts! There should be "most posts" list somewhere.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 05-20-2008, 02:50 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
I'm pretty sure cab mounts are different for 3/4 tons versus half tons. I'm sure someone who knows for sure will chime in though.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-20-2008, 02:55 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I am not sure on 3/4 tons but I do know the 67-68 core support mounts are different from the 69-up on the 1/2 tons.IIRC most kits contain the core supports for the 69-up and are labeled 67-72.It causes this problem on the 1/2. Maybe someone will chime in with the info on the 3/4.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-20-2008, 02:58 AM   #5
Sinister
Between Trucks...
Sinister's Avatar
Found this: http://www.lmctruck.com/ICATALOG/CB/full.aspx?Page=91
The cab mounts are different for 3/4 and 1/2 tons.
Beat it to fit,
Old 05-20-2008, 03:22 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
Looks like I need to look for a 67-68 front core support bushings.... Hmmm maybe I can shave em down? Hot ureathane sure sucks though.... Thanks guys...
MEMBER #6377
Project "7DEUCE"
