05-18-2008, 02:39 AM | #1 |
sound deadener !!HELP??
can any one help me understand how to sound deaden my truck. I really like the raamatand fatmat but not fully understanding the steps to do it correctly, do i just need the mat to do thee doors and cab floors or do i also need the fabric and spray on adhesive? please help me with any feed back and pictures thanks
05-18-2008, 02:53 AM | #2 |
yeller
Re: sound deadener !!HELP??
Here is my install
http://www.73-87.com/7387garage/inte..._deadening.htm And one from CCT http://www.73-87.com/7387garage/inte...ning%20CCT.htm
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
05-18-2008, 03:09 AM | #3 |
did you use any exxtra padding between that and carpet, what about your doors how did you do them.?
05-18-2008, 03:24 AM | #4 |
i started a thread on my interior a few weeks ago. here is the thread. Just stick the stuff to the bare metal and put carpet, trim, etc. over the top of it (just be sure to mark any and all holes for reassemble purposes)
http://67-72chevytrucks.com/vboard/s...d.php?t=286470 |
05-18-2008, 03:45 AM | #5 |
thanks for the help how much fatmat did you use on everything and how much did it set you back.
05-18-2008, 06:34 AM | #6 |
i got it off of ebay for 135 bucks for 100 sq feet and i put 2 layers on the floor pan, 1 layer up the back, 1 layer on the door panels and i have approximately 15 sq feet left so i might put another layer on the doors and some inside the kick panels. I haven't driven my truck since i installed it but i have started it and it definately is ALOT quieter and has zero rattles now and that is at all rpm's. I am very pleased with it for the cost.
05-18-2008, 10:18 AM | #7 |
>130dB Moderator
Here's three pics of when the deaner was being done in my truck for the second round of stereo mods. In these pics they hadn't finished the doors, but as you can see, the material will adhere to a painted surface. Layer the carpet padding ontop of that before you lay your carpeting and wiring.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
05-18-2008, 10:40 AM | #8 |
It Is What It Is,,,,
Sound deadener material is just about one of the best upgrades you can do.
Ive only done my doors in that brown bead. What a difference that just made.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
05-18-2008, 01:03 PM | #9 | |
DAMAN02 i was under the idea that i needed to rolls to do my whole cab the way you did only 100sqft did it for you doors and all? sorry if i sound dumb just want to get this right the 1st time. |
05-18-2008, 05:30 PM | #10 |
yes 2 rolls of the stuff i used got me completely done and they were 50 sq feet per roll.
05-19-2008, 02:14 AM | #11 |
>130dB Moderator
The padding is basic "juke" padding that you should be able to find at a home improvement store or upholstery shop.
EDIT: Dynamat makes a material (Dynaliner I think) that is very simliar to the padding I have, but weighs in at 3lbs/sq.ft. It dampens the actual sound instead of canceling vibration which is what normal Dynamat does.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. Last edited by AceX; 05-19-2008 at 02:17 AM. |
05-19-2008, 04:13 AM | #12 |
I just finished putting 50 sq ft of b-quiet on my cab floor. I just laid my black carpet kit on top without clue just incase i needed to take it out further down the road. Also, to my surprise, i ordered a black carpet kit from stockinteriors.com to save a little money and they shipped me an acc carpet kit.
Mexican |
05-19-2008, 09:26 PM | #13 |
thanks for all the great imput guys now which is the best to go with besides dyno-mat
05-19-2008, 09:40 PM | #14 |
The biggest difference I noticed was when I did the inside of my doors and inside my door panels. I had already gutted the doors (no glass or window regulators in my way) and mainly just wanted to see what would happen. All I can say is wow.
I used the cheapest stuff I could find, "Peel-n-Seal" from lowes. Less than 15.00 per roll and soo far have 6 rolls worth of it in my truck. ONLY my.02 worth. |
05-19-2008, 10:07 PM | #15 | |
05-20-2008, 05:44 AM | #16 |
took 5 days for mine to come in from ebay.
05-20-2008, 12:22 PM | #17 |
>130dB Moderator
The doors and the floor pan will make the biggest difference.
05-20-2008, 03:51 PM | #18 |
i found this article while researching sound deadeners...it does A LOT of testing and has some recommendations
http://www.sounddeadenershowdown.com/conclusion/ it stated Second Skin http://www.secondskinaudio.com/ was the best quality and RAAMmat BXT http://www.raamaudio.com/cgi-bin/index.cgi was the best value i havent used either one4 of these products myself so i cant confirm, just passing the info along |
05-20-2008, 04:03 PM | #19 |
Low & Fast!
100 sq ft of b-quiet shipped to the house for $130.
