Old 01-31-2003, 04:18 PM   #1
jer
model code ?
good day.
I just picked up a '67 chev lwb 3/4 t. It came with a stepside box but of the wrong year ('60-'66?). I want to find out what the truck is supposed to have but the model code on the inside of the glove box door has been painted over is there another spot that has this info or some way of finding this out??
thanks,
eh!
jer is offline   Reply With Quote
Old 01-31-2003, 04:38 PM   #2
smokekiki
Mike
smokekiki's Avatar
Should be in the VIN # should have 2 letters and then the first # is the gvr and the next# is the bed. if it's a 4 it's a stepside
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 01-31-2003, 04:55 PM   #3
jer
thanks guy i'll check it out
but if any body knows how to find out what was on the g.b.d. I would sure like to know.
'67 Chev lwb soon to be daily driver
'68 Mustang 390 gt/California Special full(very slow)restoration
'77 T-Bird retired due to 400cid
Old 01-31-2003, 05:54 PM   #4
Josh
He's got mean nasty FANGS!
Josh's Avatar
All the VIN will tell you is if it was a Chassis/Cab (no bed, or flatbed) or a Cab and Bed combo, 4 means Cab and Bed, 3 means Chassis Cab. I'm not 100% sure on this, but I believe if you contact GM of canada (assuming it was built in canada) you can get a copy of the original options when you request a restoration pack, only downside is it costs $50 I think.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 01-31-2003, 05:57 PM   #5
Josh
Josh's Avatar
For more info on VINs and model codes go to: http://67-72chevytrucks.com/Chevyear.html
2004 K2500 Burb
1999 C3500
1969 C-10
1967 C-10 Panel
Old 01-31-2003, 08:19 PM   #6
jabarlow
depending on what shape mine still had the model no on the rear frame cross support facing the back just a shot
72 Chevy K10 Short Stepside
72 gmc K2500
jabarlow is offline   Reply With Quote
Old 02-01-2003, 01:10 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The bed you have should be the same box, all you need is the proper fenders to bolt on.
Old 02-01-2003, 01:24 AM   #8
Hutch
Hutch's Avatar
You might check inside the seat or behind the gas tank for a build sheet. Other folkes have found them but not me.
Do a search on the site for build sheets there should be some good information in the archives.
The glove box data sheet on my trucks had plastic covering them
If the data sheet is still attached there may be some way of removing the paint and still be able to read it.
Just a thought
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 02-01-2003, 03:20 AM   #9
jer
a wealth of information!
