Dual or Single Exhaust?
I have a recently rebuild 307 engine and im thinking about doing the exhaust. Which would be better a 2” dual exhaust with dynomax super turbos, or a single 2 ¼-½" with one super turbo.
Thanks Eagle
77 C10 truck 355/TH350, 10:1 KB's, COMP XE256H, EDELBROCK PERFORMER, CARTER 600 CARB. |
Location: Bondurant, IA but in Worcester, MA for school
Duals!!!
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
Formerly yellow72custom
How loud do you want it to be? The dual exhaust would be a bit quieter because it has 2 mufflers, while the single would have one. I would be tempted to get a single 2.5" pipe, and a Dynomax Hemi Turbo muffler, which is like a quiter Super Turbo. Power will be about the same for either system.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Half a bubble off!
Nothin' sounds better than a nice set of duals. Single exhaust is for granny's car.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
barn's right, single exhaust is for nancy boys. Go for the duals. You might want to look in to a set of glasspacks. Lots of people don't like the sound. Personally, I don't think you can beat that sound on these old trucks. There are many different option you can go with in the packs. I used to have a set of 24" packs on my truck. Not too loud just a nice rumble but talked when you put you foot in it. Best of all, they are cheap.
72 Cheyenne 1/2T LWB original ochre/white 09 Silverado ECSB 76 International ScoutII |
its all about the +6 inches
As much as I like a set of chrome tips hanging out from under the bumper, a single pipe is cheaper, and performace wise, your 307 (I asume stock) is not a fire breather and little gains would be seen with a set of pipes verses a good single set up.
Onless you are planning on a larger engine in the future, and if you are trying to watch the out going cash flow, (or the wife is watching that for you) I think i would go with a single pipe system. |
Duals will give you less restrictive exhaust, even with one 2 1/2" exhaust.
Cross sectional area of a 2 1/2 " pipe is 4.9 square inches. With 2" duals, the area is 6.3 square inches. Jim |
Fabricate till you "puke"
I am a fan of duals! I ran 2" pipe , with H pipe , superturbos, & side exit tail pipes(behind the wheels) on a 305 powered flatbed. The system sounded nice......not too loud, but you could hear it. the H pipe in the system will mellow the note & give a more "tuned" sound......also helps with the low & midrange tork. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
JimKshortstep4x4 is right, however, you can go too far with pipe size. It is not as dramatic as picking a huge tube header, but too much pipe Cross sectional area will kil your lower end torque...which is all a 307 has going for it.
2" pipe should be fine on the 307......I wouldnt go any bigger tho........crazyL
twice pipes!
72 short wide 55 stepside- 2nd generation "come on honey, we need more old trucks to fix up for the boys to drive, they will be driving before ya know it!" |
Don't mean to steal your post eagle.....
Would 2 inch duals with the "H" pipe be the way to go for a 72 4X4 also? No headers yet........not sure about them. Can you add headers later to a setup like this if you choose to do so? Suggestions? Stock 350.......will be rebuilt soon with a bit more goodies in it but no race car intentions.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air 2000 Harley...Wide Glide |
gman, the 4x4s take a little more power to turn everything......I would run 2" on a pretty mild 350. If it was a 2wd, I would think about going 2 1/4" on the pipe. As far as the headers, due to the "fun way" the 4x4 pipes lace in, i would install them before the exhaust was done to save on headaches later. crazyL
Hootis is as Hootis does...
2 pipes. 2 cool.
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires 1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires 1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires |
#15 |
Half a bubble off!
I had duals (with an H pipe) on another truck that had a 307 in it, and I never regretted it one bit. I had the duals with H on my current truck before I changed to headers, and the change was no problem. Anyone that knows his stuff can mate them up with no problem. And I also feel very strongly that any dual system should have either the H or an X pipe. I also like glasspacks, love the sweet sound of dual glasspacks rumbling! Single exhaust is just plain LAME !
#16 |
I have mated headers to an existing system, but just as an observation(from working in an exhaust shop)....once upon a time! The systems are much cleaner looking, & will have a couple less splices in them if all the work is fitted/ done at the same time.....crazyL
#17 |
Thanks Guys for the replys the reason I was asking was the exhaust is going on my sisters car, its a 69 chevelle malibu right now it has a 2.25" single exhuast with a stock muffler and catalytic converter someone put on, before we bough the car. She does not want to be loud. But price wise how much would a complete 2" dual exhaust be with two dynomax super turbos vs.
a single 2.5" exhaust with one dynomax super turbo. The whole exhaust needs to be done from the exhuast manifolds to the muffler(s). Thanks Eagle
#18 |
Price would depend on the area & how much competition there is in exhaust work. In my area, I would say in the range of $250-300 on the duals, & the single exhaust might be $75 cheaper. good luck, crazyL
#19 |
tranny interference
Does anyone try to route exhaust and H pipe so the tranny and transfer case if so equiped can be removed without butchering exhaust? Any tricks?
Bob |
#20 |
Registered Cruiser
If you put a coupler (flange) on the crossover pipe the exhaust can be easily dropped out of the way.
I intend to live forever. So far, so good. |
#21 |
Its Magically Delicious
get duals .....straight out the back .....
#22 |
I think I'll try a single 3" sustem with a 3" flowmaster when I get my big block in; out the side behind the rear wheel because I tow so much.
