Old 05-23-2008, 07:52 PM   #1
Larcifer
66 front brake drums
I'm a newbie and this site ROCKS!
Here's my first post and it seems a little dumb but here goes. I'm replacing the front drums on my 66 and the new drums have no adjustment slots nor does the backing plate. Local brake warehouse claims they don't make drums with adjustment slots anymore. They said I have to do it manually with drums off. If this is the case any pointers.
Larcifer is offline   Reply With Quote
Old 05-23-2008, 08:55 PM   #2
61hawk
61hawk's Avatar
Re: 66 front brake drums
When I bought my new ones for the rear, there was a knockout stamped into one (but not knocked out) and nothing on the 2nd. We had to drill and cut a slot into both.
Adjusting them with the drums off sounds fun... how many times do you have to take the drums off during an adjustment, about 20???
61hawk is offline   Reply With Quote
Old 05-23-2008, 09:56 PM   #3
steverino66
the ones I bought recently at NAPA had the knockouts cut but still in place, sort of an oblong slot - a punch and a few whacks with a bfh took care of it
steverino66 is offline   Reply With Quote
Old 05-23-2008, 11:10 PM   #4
1966-Suburban-V-8
1966-Suburban-V-8's Avatar
... They said I have to do it manually with drums off. If this is the case any pointers.
Indeed it DOES!
Here's a shot of my brakes - may help to see one set up that works Very Well - I see no need for changing over to discs.
Dan
1966 Chevy Suburban 'Gater - Shop Truck - 350/turbo 350
Power Steering, B&M Floor Shift, Dual side dump exhaust
Chrome Rally 6 lugs. (((XM)))tunes!
1965 Riviera 425 - Luxury Muscle - Fully Factory Loaded. All power, A/C, Custom Interior, Guidematic Dimmer, AM/FM - etc, etc
1966 Corvair Corsa Turbo - Factory Sport Model - Quick steering, F-41 HD suspension, Positraction, Tele Wheel.
1966-Suburban-V-8 is offline   Reply With Quote
Old 05-24-2008, 03:03 AM   #5
billydonn
Council of the Elders
billydonn's Avatar
Originally Posted by 1966-Suburban-V-8 View Post
... I see no need for changing over to discs.
Dan
Please don't get offended, but:
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 05-24-2008, 06:03 AM   #6
scotts62
One day...
scotts62's Avatar
Ya if i would have had to take the drums on and off more than a couple of times, i would have cut or drilled a slot in the backing plate!! forget that! modify it
Scott
93 crew cab build
Project 62
Old 05-26-2008, 03:38 AM   #7
Larcifer
Thanks for the info. One ended up having a knockout tab and the other didn't, I'll modify it at a later date. Thinking discs will be the way to go.
Thanks for the pic
Old 05-26-2008, 03:50 AM   #8
scotts62
One day...
scotts62's Avatar
Oh ya disc is they way to go for cruising
Its not a real hard upgrade either.. well if you use a donor truck and not go all out with expencive stuff
Scott
93 crew cab build
Project 62
