HF ball joint press question
Hello all,
Does the Harbor Freight ball joint press come with the proper sleeves to remove a ball joint from a 77 dana 44?? I see they sell an expansion kit and was wondering if I need that too or can I get by with the couple recieving tubes that come with the actual clamp set?? Thanks |
Re: HF ball joint press question
Mine came with the right tubes, but it was more than 10 years ago.
I've also used schedule 80 pipe in a pinch. |
Everything is work in progress
![]() Join Date: Apr 2006
I found the standard kit is a pain. I wish I'd bought the expanded kit.
just my 2 cts worth.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
Thanks for the input.
What made the standard kit a pain? Did the c-clamp hold up okay? You know that HF stuff. |
Its lookin' like a Blazer!
Be sure to lube up the screw in the clamp with some bearing grease or something thick like it. Makes it work like an expensive one, lol....
The clamp worked fine. It's the spacers and shims that didn't work to well with the dana 44 front end. You need the other spacers (expanded kit) for the clamp to work properly.
