door adjustment -
Does anyone know if it's possible to adjust the door hinges that attach to the body while the door is on? It's a PITA to take it off- I would think there would be a special wrench or something...
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Re: door adjustment -
here is a link to a door wrench photo http://images.google.ca/imgres?imgur...%3Den%26sa%3DN
Trueman Last edited by 463; 05-27-2008 at 02:15 AM. |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
I made couple wrenches with a torch and some old 9/16" comb. wrenches. Looks similar to the pic in the above link, just a shorter version.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
Hmmm. Linky's expired. I think I'll just pull the door for now and guess where they should be - looks like a handy tool, though.
#5 | |
Trueman |
Velocity Speed Shop
I have a suggestion for you before you pull the doors, hopefully you have'nt before you read this. Get a drill and a 1/8" drill bit, open one of the doors, drill a hole through the UPPER hinge and into the door frame, then do the same to the lower hinge. Of course you need to make sure that the doors are lined up before you do this. Then after all body work and paint are done all you have to do to put the doors back on is stick that same drill bit back into the holes you drilled, bolt it up and the doors should be lined up. Any questions?
--------------------------------------------------- My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143 My Garage ..... http://www.hubgarage.com/mygarage/OCD69 Last edited by jgrisafi; 05-28-2008 at 07:26 AM. |
