Old 02-02-2003, 10:15 AM   #1
jmanz69
Careful, they attack...
jmanz69's Avatar
Anyy diff's on dash harnesses?
I have 3 underdash harnesses, and I was wndering if there is any diff between the trucks that had AC and the ones without in these harnesses. I know all of the ones I have are for the gauge dash.
jmanz69 is offline   Reply With Quote
Old 02-02-2003, 12:08 PM   #2
Andy4639
Old member
Andy4639's Avatar
Cool Differences
Yes there is a difference. The wire harness forr the AC will have a 40 amp fuse at the fuse block with the wires running to the ac in the dash with the two little light bulbs. If my memory is right I think it's a orange wire, it will have the relay, compressor clutch, and anti dieseling wires also.
Hope this helps.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-02-2003, 12:14 PM   #3
jmanz69
jmanz69's Avatar
so the one I have pictured is probably for a non-AC truck then. I will ahve to look closer and see. Anyone have a pic of an AC dash harness?
