Progress Pics.
Here we go this is going to take a while .
1
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
2
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 01-30-2003 at 11:20 AM. |
I dont know if this will work.
2
That's my dad !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 01-30-2003 at 11:57 AM. |
scanning pitcures sucks! I cant waste any more time here they are not worth posting they look so crappy. I dont know how to properly resize them. the way I don makes them look like crap. Later
making progress
PROJECT 7DEUCE
![]() Join Date: Dec 2002
What kind of rotors are on the front they look to be cross drilled????? Nice looking ride by the way.....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Do you have a '67 front on that truck? Lookin' Nice!!!
Brandon |
where did you get the flip down tail light for the gas filler. I was thinking of relocating my gas tank and wanted that same setup.
shawn
71 C/10 Short Wide 2/3 drop, 383/350/3.08 posi in various states of repair growing into 4/5 drop 383/700R4 |
Working on a Nova.
I wish I had heat in my garage so I could get back to work!!
![]() Looks like you are doing good! Keep it alive!!! |
They are stock rotors form Napa. The pic is awful they kinda look cross drilled I know you can buy them from Early Classic it's just somthing you can buy at a later date I dont think that they will make that big of diffirence.
That is a 67 front clip. I was told you can use your stock rad support but it does not fit even after removing the head light buckets so I found a 67 one to put in. I am just fabing it up myself I have a gas door from a 87 burb that will be my hing doner Have not finished it yet because I dont have a floor so I cant line up the fillerkinda stop work on that part because I want to get the front all together- what ever I will finish it when I get the box on the truck. There is a post on the paint and body message board on the Gas Filler Ideas I gave it a TTT The shop is nice some days its warmer than the house! Later Mario
