Luv the Crewcabs
Swap from 3/4 to 1/2 Ton Spindle?
Do u Have to Change out the a-arm's for this swap or can you just swap out Ball Joint's?
I know that the 3/4 & 1 Ton use the Same Ball Joint's, Just Not Sure if the A Arm's are Different or Not? Thanks, Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: Swap from 3/4 to 1/2 Ton Spindle?
The upper joint can be swapped out but the lower control arm will have to be swapped out since the LBJ is pressed into it and the outer diameters are different between the 1/2 ton and the 3/4 -1 ton ones (smaller diameter)
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
67-72 parts collector,…
![]() Join Date: Nov 2002
ECE also makes a "conversion" drop spindle that uses stock ball joints and accepts 1/2 ton brake components.
