Old 05-31-2008, 02:11 PM   #1
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Rear slider removal
I found a truck in a local yard with a factory slider. What is the easiest way to remove it? Is it as easy as cutting the gasket and poping it out? Anybody with any tips or tricks?
Jason
jay_shy is offline   Reply With Quote
Old 05-31-2008, 02:32 PM   #2
estig70
estig70's Avatar
Re: Rear slider removal
Jason
Just removed mine last week with soapy water and a couple screw drivers, alot of patience and time.
Start at one of the upper corners and work it out a little at a time.
Again, take your time and be patient, use as much soapy water as you can and you'll have it out unscathed.
Good Luck.
Eric
estig70 is offline   Reply With Quote
Old 05-31-2008, 03:54 PM   #3
Psycho71
Psycho71's Avatar
I cut mine out with a utility knife. Mine wasn't a slider, but I figure the rubber would be the same. It was easy as can be since I didn't want to keep the rubber.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 05-31-2008, 04:17 PM   #4
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Thanks guys. I am heading out now to give it a try. I will let you know how it works out.
Jason
Old 05-31-2008, 07:34 PM   #5
estig70
estig70's Avatar
Jay
deffinately alot easier than my method, of course I was saving the rubber.
Eric
Old 06-02-2008, 07:47 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
or you can buy them for $30 at a pick-n-pull.
DO NOT use dish soap. it makes it more difficult. use the slimey hand cleaner like gojo. trust me, I learned the hard way.
68C15 is offline   Reply With Quote
Old 06-02-2008, 08:08 AM   #7
70cst
70cst's Avatar
Originally Posted by 1969stepside View Post
you can buy these new still
Do they look factory? Cost?
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-02-2008, 08:43 AM   #8
1969stepside
1969stepside's Avatar
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 06-02-2008, 06:56 PM   #9
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
the owner said he crushed the truck the day before I got there.
Would like to know where I could buy a new one and what do they cost?
Jason
Old 06-02-2008, 07:44 PM   #10
1969stepside
there is this place where i live that is called doozy and they sell them new i can find out for you
Members i Have met
Earl Slick68
Old 06-03-2008, 11:10 AM   #11
estig70
estig70's Avatar
Jason
Scroll down, to view all the board vendors. http://67-72chevytrucks.com/vboard/showgroups.php
you might find what you need.
Eric
