Old 05-31-2008, 05:52 AM   #1
truckdude239
truckdude239's Avatar
how to adjust a qjet
i got a 4 barrel qjet i need to adjust the floats on because my truck keeps flooding how would i do this?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-31-2008, 06:17 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: how to adjust a qjet
Does this help?
http://www.4wheelnoffroad.com/qjet.html
Make sure the float dosen't have a crack or pinhole in it and if it's plastic it may be soaking up fuel and becoming heavier. This will cause flooding also.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-31-2008, 01:30 PM   #3
truckdude239
not really this is a reman carb it runs good but i bought it almost a year ago and just now installed it but the warranty is gone on it
David fuller
2000 Tahoe 5.3l 378
Old 05-31-2008, 03:36 PM   #4
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Hold down GENTLY on the needle side and push down on the float. Careful or it'll fold up. You have to make sure that the float is not rubbing up against the side of the bowl too, or it will bind and keep flooding. They may well be your problem to begin with, especially if it has been tossed around some in storage. Or you could have a piece of trash under your needle.
Oh, and one more thing, make sure your float is clipped to the back of the float arm, if it isn't, that'll cause it to flood too. But that is probably not your problem since you bought it remanufactured (I would hope not anyway).
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
