Old 05-30-2008, 04:23 PM   #1
nico
nico's Avatar
Question Adding A/C to a non-A/C Truck...
As the temps keep rising, I'm seriously considering adding air conditioning to my non-air 1984 SWB... I may have located a good donor (1980 with working A/C, heading to the crusher). What all modifications are necessary to accomplish this? Anyone have pics of the differences between the dashes and cabs?
nico is offline   Reply With Quote
Old 05-30-2008, 04:35 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Adding A/C to a non-A/C Truck...
I don't have any info to share, but sure will follow this thread if you keep it updated. I'm debating the same "upgrade" for my '87. What I do know is the ductwork under the dash is different.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 05-30-2008, 04:43 PM   #3
beaterC10
I would consider an aftermarket approach to adding AC to a non-AC truck. The factory approach requires sheet metal mods to the firewall to accomodate the system differences. You will probably also end up taking most of the dash apart to complete the swap.
beaterC10 is offline   Reply With Quote
Old 05-30-2008, 06:07 PM   #4
boatpuller
boatpuller's Avatar
i don't have cab pics.but i added aftermarket a/c to an a/c cab.vintage air can fix you up.but,it will cost you over a grand.if you go that route there is a few of us on here that have done and will be glad help.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 05-30-2008, 06:44 PM   #5
nico
nico's Avatar
That may be the best approach... I really enjoy having a non-A/C firewall when doing engine work. Do you have any pics of the vintage air unit installed?
Old 05-31-2008, 03:20 AM   #6
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
I just started looking into it but I heard the other day that there is an a/c unit the runs off electrical instead of being belt driven. The advantage being you don’t have the engine drag from the compressor so you don’t lose gas mileage while you’re running it. I believe you would have to put in a power inverter, a second battery and a stronger alternator. But like I said I just started looking into it, I’ll let you know what I find out.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 05-31-2008, 04:07 AM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
first off the heater box is different and there is a front section you have to bolt up and yo have to make holes to accomodate the studs and bolts there was h oles that had to be made to accomodate the evaporator?? i forget what its called and then theres all the vents and vacuum and the different kick panels and all i started doing this on my 76 years ago but like i have said many times this was my sons truck and when he messed up we scrapped the project and sold it .. i never got it completed but it was a PITA
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-31-2008, 07:23 AM   #8
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I'm using Hot Rod Air. I have not received my order yet as a takes a few weeks to put the kit together. My order was under a grand and it comes with everything. I have a shaved firewall and the only thing sticking through will be the four hoses (A/C and heater hoses).
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-31-2008, 12:32 PM   #9
S10Fan
Old Heap Driver
I'd go with aftermarket. My S-10 will be getting a Vintage Air A/C Heat Defrost setup this winter.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-31-2008, 06:15 PM   #10
boatpuller
boatpuller's Avatar
http://www.classictrucks.com/tech/06...oning_install/
here's a link to an install that classictrucks magazine did on one of our trucks.it's worth reading for anyone considering the installl.i actually refered to it during mine as kinda a guide/manual type thing.i included an old pic i had that everyone seen a hundred times.but, it show's the firewall panel that covers the old heater box.i went with vintage air mainly because of the "sure fit" system.turned out it wasn't as easy as "sure fit" sounds....but,highly doable.and works excellent.
Old 05-31-2008, 08:05 PM   #11
nico
nico's Avatar
Very nice boatpuller... Thanks for the advice.
