Re: Blazer Tailgate Band on P/U Tailgate?
You will need the inner mount froma truck tailgate band and the outer panel from a blazer to work on your truck. The outer panel is crimped around the edges. You can bend the edges back enough to remove the inner support(mounting bracket) and install the pick up mount. I hope this helps you.
| Bookmarks |
