Old 06-05-2008, 09:37 AM   #1
jkaylor68gmc
jkaylor68gmc's Avatar
Coil Spring bolt size Help?
After removing my dads springs last night ifound there to be no nuts welded to the inside of the cups on the bottom. I want to pick up some new bolts tonight. I figured grade 8 bolt with a washer running up through the bottom with a washer,lock washer and nut on top. SInce they run through the trailing arms doese anyone know how long they should be? I forgot to measure when I was there.
thanks
josh
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 06-05-2008, 10:22 AM   #2
Green Machine
Green Machine's Avatar
Re: Coil Spring bolt size Help?
Just bought some here. 1/2 inch by 5 inch grade 8 is what I use. Get the grade 8 washers too. We put the lock washer under the head on the bottom, if it matters any. So we go from bottom - bolt-lock-flat-arm-spring-cup-flat-nut.
Top takes a 2 inch long bolt, 2 1/2 fits too, just more threads hang out. Here starting from bottom we go - bolt-flat-cup-spring-frame-lock-nut.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-05-2008, 10:24 AM   #3
jkaylor68gmc
You are the man, thanks a ton. That is exactly what I was looking for.
1962 swb fleetside
