06-03-2008, 08:12 AM | #1 |
Robert Olson Transport
could someone please post a pic
I need someone to please shoot a pic and post it here of the factory spare tire mount and hardware under the rear of our trucks... i think they are the same from 73-87 but im looking for one that is going to be used on an 82 truck so if there are any differences thats the one i need.
thanks in advance
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
06-03-2008, 10:14 AM | #2 |
www.73-87chevytrucks.com
Re: could someone please post a pic
Of it installed or the pieces not installed?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-03-2008, 11:37 AM | #3 |
either way i guess one of my buddies here is checking to see if he has it used on one of his parts trucks and wants to see exactly what i need ( which is all of it)
are theres available aftermarket new?
06-03-2008, 11:39 AM | #4 |
I don't think these pills work
These May Help But It Was Real Sunny Out
SQUARE84 90 SUBURBAN |
06-03-2008, 11:43 AM | #5 |
that works thank you very much!!
06-03-2008, 02:11 PM | #6 |
Bob,
FYI: You are looking at used/salvage for these.
06-03-2008, 03:06 PM | #7 |
I recently removed the stock size spare tire from the spare rim and kept one of the old slightly wider tires I was removing only to find it didn't fit back under the truck. I had to lengthen that threaded rod (in that 2nd pic above) Just barely had enough to make it work. Was a real pain since it had 24 years worth of dirt and rust on the threads.
Paul 1984 Chevy C-10 *LWB/305* |
06-03-2008, 03:10 PM | #8 |
If Youll Notice Mine Threaded Rod Is Bent From The Breaker Bar I Had To Use To Get The Nut To Turn.
06-03-2008, 05:47 PM | #9 |
BTW, you may consider looking into using a newer version off a 88-up that has the actuator that is turned by the tire tool... That big bolt can become a serious PAIN.
Best pic I could find... http://www.sirmichaels.com/display_part/47.php
06-03-2008, 07:02 PM | #10 |
Mine was bent too, been that way ever since I got the truck a few years back since I never needed the spare (knock on wood). But while I had the spare out, I took that funky sheet metal adjustor nut off and took that rod out and straightened it. I didnt' think it would come out at first, thought there might not be room with the bed in the way, but there was room to get it out.
06-03-2008, 09:47 PM | #11 |
ill prolly have to get new threaded rod then as i have P235 75 R 15s on my truck and i believe they came stock with 225s
06-05-2008, 10:31 AM | #12 |
I think the old spare I removed was a stock size 225, and the rod (which is actually just a real long bolt) on the permanently attached end (in the second pic above next to the two exhaust pipes) was set at a length about like that picture. The nut you see in the picture is jam nut, and there's another nut in the channel above, took a box end wrench to get at it. The tire I kept for a spare is a 255/70-15, so there was no way it was going under there with the bolt at that setting. I had to lengthen that bolt using most of the thread that was left. On the end of the spare holder that opens up , I do have a few threads sticking out the bottom of that cheesey sheet metal nut, so the 255 size tire did fit. I'm sure so a 235 should fit with only minor adjustments.
06-05-2008, 11:39 AM | #13 |
235/75 will fit with the factory parts. I am running this size on my 78 k-10 with a 8" rally as a spare and it works fine. I bought new bolts and nut from GM a couple of years ago, but I see now the bolts are no longer available. A dealer my still have some in stock. If you want the part numbers, let me know.
