Old 06-05-2008, 04:30 PM   #1
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: 4l80e and shift linkage
Joe, a 700R4 (4L60) is the same basic case as the 4L60E. Not sure why it won't go into 1 as the linkage should the same.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-05-2008, 06:45 PM   #2
OJOE
Crew Cut
OJOE's Avatar
truck came with P R N D 2 1 ,no over drive.
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 06-06-2008, 02:00 PM   #3
Captkaos
Captkaos's Avatar
The indicator in the bezel is the only difference comparing TH350 to 700R4, so it should still go the full range.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 06-06-2008, 07:36 PM   #4
OJOE
Crew Cut
OJOE's Avatar
me dont know. i had thought about changing the column for one i have out of a overdrive truck. but i guess that would not work. i have seen other builds where you could not shift to first?????????
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 06-26-2008, 09:51 PM   #5
454HO
I finally got home from China. Here are the pics of how I did mine.
Basically just lengthen the rod by about 2-1/2" and move the pivot point toward the rear about the same amount. Works great with the original column. I just need to get a gear indicator that has the Overdrive position.
- Greg
454HO is offline   Reply With Quote
