Old 06-05-2008, 10:28 PM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Transmission dust shield
Is the transmission dust shield for a turbo 350 and turbo 400 the same? Thanks
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 06-06-2008, 08:32 AM   #2
myoldchevytruck
Question Re: Transmission dust shield
Little help please? Thanks.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 06-06-2008, 09:29 AM   #3
cwilli84
1FINE69
cwilli84's Avatar
No. they are different and you have to watch out for the pontiac versions with a starter on the opposite side.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD
cwilli84 is offline   Reply With Quote
Old 06-06-2008, 09:30 AM   #4
cwilli84
1FINE69
cwilli84's Avatar
Check a catalog and they will show you different part #s. National parts depot or a board vendor should be able to tell you more about it.
Old 06-06-2008, 10:19 AM   #5
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
TH350 and TH400 use the same inspection cover.
ProStreet68SB is offline   Reply With Quote
Old 06-06-2008, 10:25 AM   #6
Steven B
Steven B's Avatar
Chevy T350/T400 same cover. Don't know about the BOP ones.
70 Jimmy 4x4
71 GMC 2500
Too bad stupidity isn't painful
Steven B is offline   Reply With Quote
Old 06-06-2008, 11:48 AM   #7
myoldchevytruck
Thanks for the info guys. I'm still confused. One guy says different and 2 others say the same. Here's a pic of the cover I'm asking about. Thanks.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 06-06-2008, 08:05 PM   #8
JimKshortstep4x4
The covers are different as the TH 400 cover has a different hole spacing on one side. Attached is a picture of a TH 400 cover, (in front) and a TH 350 cover (in the rear). The TH 400 cover has pointed ears on both sides but the TH 350 has only one pointed ear.
You could probably redrill the transmission to make the TH 350 cover fit a 400 but I have never tried it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-06-2008, 11:49 PM   #9
myoldchevytruck
Jim
Jim,
Thanks for confirming this. Thanks for the pics.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
